586,106 active members*
3,177 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Align face with a plane
Results 1 to 6 of 6
    Apr 2016
    102
    Hello All
    I get a lot of files from my customers where the model is not sitting in an ideal position to start layout work.
    In the attached file I wanted the green face to be sat flat on the X,Y plane, I do manage to get the model into the required position by a lot of jiggling around measuring angles and applying rotations.
    Is there a quick way to get a model like this aligned to a particular plane?
    Barrie
    Barrie @ Composite Specialities Ltd. using BobCAD V29 Mill 3 axis Pro, Geomagic Design, Bricscad V16 and MOI V3
    Mar 2012
    1570
    Re: Align face with a plane
    When you say layout work you mean, programming the part ?
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Apr 2016
    102
    Hello Al
    Yes programming but also setting up boundaries etc, My OCD makes me want to get the model lined up like it would be on the bed of the machine.
    I do heaps of programming with BobCAD probably 3 jobs a day at the moment with multiple setups but this issue bugs me.
    Barrie
    Sep 2012
    76
    Drives me nuts also. In automotive, the part is oriented with the car center, which is feet away and in a goofy place. The only solution I have found is asking my customer to orient in a specific way. It is particularly challenging in Solidworks.
    Apr 2016
    102
    Wolfman
    I dont much like asking my customers do things like that for me, they come to me for solutions not more problems.
    Generally I am creating some wireframes usually with the section view tool then making angle measurements back to the X,Y and Z planes and rotating the model accordingly, it is a bit of a work around though.
    I thought 0,0,0 on an auto/car was the mid point of the ground plane on the front axle line?
    Most of the parts I deal with come from yachts and are sent to me in the orinitation that they sit in the hull assembly.
    I think I am going to raise this and the clutzy rotate command as future improvements with BobCAD.
    B.
    Sep 2012
    76
    Not a bad idea. Solidworks is what really drives me nuts, as I use the solidworks drawing as a master for the tool design. On some materials I have to re-draw to allow for material changes, but frequently not. Thanks for including in for future BC.
    Agree that they come for solutions, but in our case theyu always want stuff the day before you get the drawing;-) If they want it fast, they can help a little.
  1. Feed Plane Overwriting Rapid Plane V26
    By Jbrown74 in forum BobCad-Cam
    Last Post: 02-21-2014, 02:17 AM
  2. Align face to horizontal using probe - DMU50
    By David Kemps in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-26-2009, 07:55 AM
  3. Align Honing or Align Boring ?
    By jonbanquer in forum MetalWork Discussion
    Last Post: 11-09-2008, 04:33 PM
  4. construction plane and tool plane
    By nervis1 in forum Mastercam
    Last Post: 11-05-2004, 06:53 AM
  5. cycles initial plane/retract plane
    By HuFlungDung in forum OneCNC
    Last Post: 06-27-2003, 01:02 AM
