586,068 active members*
4,334 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > K40 whisperer w40 laser tube arching from the end of the tube HELP
    Hi guys ive just run into an issue with my engraver it was running a job fine it was engraving lovely then suddenly stopped and there was a horrendous cracking sound coming from the back of the machine.
    i pressed emergency stop and then investigated and when the laser if fired there is a massive bolt of electricity coming from the end of the tube and earthing out to the body of the machine every time the machine fires so i am now stumped
    ive tried silicon sealant on the end as one of the other threads said but it is still arching
    so any help you guys can give would be gratefully received
    cheers
    matt
    ant sign and print
    Feb 2009
    6028
    Re: K40 whisperer w40 laser tube arching from the end of the tube HELP
    Try changing your water with fresh distilled.
    Sep 2005
    1740
    LOL changing your water is not going to fix a HV leak to ground. Remove the connection, clean up the burnt areas around the terminal because once it arcs and leaves a carbon trail it will
    keep doing it. Use MEK or acetone or the like. Cut back the HV wire until you get a un-burnt piece to work with, strip back to expose the copper wire and gently attach to the terminal. I have used
    plastic coated wire nut or wire wrap around. When you use silicone use the Red RTV stuff and make sure its set and dried for at least 24 hours. Make sure no metal is touching the wire or terminal
    insert something plastic to keep it away. If your HV wire is to short go to a automotive supply store and buy some copper core HV spark plug wire. Yes you will have to find a store that sells the
    copper core stuff, most of the kids today will be clueless.
    Sep 2005
    1740
  1. As a Laser Tube Manufacturer, How We Test Laser Tube before Shipment
    By SPT-Laser in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 01-12-2017, 08:12 AM
  2. poor power on 100w reci tube. tube is new. 1290 laser.
    By nate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2015, 07:31 PM
  3. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  4. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
  5. I changed from synrad rf laser tube to glass tube and it is not working good
    By david Neumann in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-15-2012, 03:22 AM
