586,061 active members*
4,583 visitors online*
    Jun 2019
    Post Servo Motor Fault
    Recently a servo motor was replaced on the machine, for the z-axis.
    The driver is throwing a fault error.
    https://cadcamcadcam.com/servo.aspx
    The servo is a new Hansen with a provided pigtail for the optical encoder. The exact product is not listed on their site.
    Unfortunatly, the supplier has no wiring diagram.
    We've followed their trouble shooting instructions:
    - ensure power is connected properly.
    - We've double checked the correct pigtail is in use on the encoder.
    - verrify connection cable
    - verify female jack on controller
    - modified the pots per original documentation
    Everything checks out, but as soon as we move the z-axis, the servo moves one tick then the encoder indicates a fault.
    Any suggestions would be helpful.
    Nov 2012
    1267
    Re: Servo Motor Fault
    First I would rotate the encoder by hand and see if EnA and EnB are changing.
    If the signals from the encoder are OK, I would try swapping EnA and EnB (or reversing the motor leads if that's easier).
    Jun 2019
    This seems like very high-level troubleshooting. I appreciate this, now I know where to search for my next step.
    Pre-search: I assume I'm going to find a din or similar for the hand rotation as the encoder in a fixed position. I do see that EnA and EnB are labeled - and originally expected the wiring wasn't correct.
  1. Fixed position off fault on Fanuc 18i spindle servo motor.
    By Jason 105 in forum Community Club House
    Last Post: 07-29-2013, 05:29 PM
  2. Multicam HELP? 3000 motor fault Multicam motor fault (0x 4
    By murfeedean in forum Multicam Machines
    Last Post: 11-05-2012, 02:22 PM
  3. 139 x motor z fault and occasional ground fault
    By duckslayer in forum Haas Mills
    Last Post: 05-10-2012, 01:50 PM
  4. VCE-750 with BLDC Servo - X Axis Servo fault
    By kostner in forum Haas Mills
    Last Post: 10-23-2011, 08:09 PM
  5. Replies: 3
    Last Post: 05-18-2011, 05:26 AM
