586,112 active members*
3,035 visitors online*
Thread: Angled Holes
    Oct 2006
    13
    Angled Holes
    Hello, at work I use Gibbs version 8x (It has some kind of Pro AXYZ 5 Axis thing with it), but nobody there knows how to use it beyond simple contouring etc... Pretty much all of the parts that I run have angled holes, but nobody knows how to use Gibbs to program them. As it is now, we just put it on the 5th axis and program it manually with a lot of eyeballing. I've been using gibbs as a CAD program to eliminate the eyeballing, but since I have to program new parts every night, I'd like to streamline the whole process and actually program those holes with gibbs. Any help or pointing me in the right direction would be appreciated. Thanks.
    Jan 2007
    61
    Well first I set my machine documents on 5th axis and set the proper axis setup then I create diffrent cs's,and align each side I machine. I attached a generic sample
    Attached Files Attached Files
    Oct 2006
    13
    Thanks. I need play around with it, but at least I have a place to start now.
  1. installing compound angled holes on 3 axis machines
    By krustykrab in forum Hard / High Speed Machining
    Last Post: 10-14-2007, 02:46 AM
  2. Angled Brackets
    By JohnG in forum DIY CNC Router Table Machines
    Last Post: 05-19-2006, 10:10 PM
  3. Holes?
    By saturnnights in forum SheetCam
    Last Post: 02-22-2006, 07:28 PM
  4. compound angled holes on 3-axis machine
    By krustykrab in forum Uncategorised MetalWorking Machines
    Last Post: 05-17-2004, 05:49 PM
  5. holes
    By Xeno in forum PTC Pro/Manufacture
    Last Post: 09-06-2003, 12:11 AM
