586,068 active members*
3,706 visitors online*
    Aug 2018
    20
    Crusader M series CRT to LCD conversion
    Hey guys I'm working on my friends's VC3600 mill . CRT driver board inside Crusader M series is toast. I found it had a video feed via 4 cables from PCB in the cabinet in a single 5 pin connector. And for the love of God I can't figure what kind of video feed this is and how to connect it to VGA monitor. I've measured voltage, two cables give under 1V and one gives under 3V , forth being ground. I've tried connecting to VGA to Green from RGB , and corresponding ground and pins 12 and 13 for V and H sync but without success . I've seen people put computer monitors on these but couldn'f find how they connected them.When I was trying to plug cables around pins on occasion monitor would say unsupported signal/
    Any help would be highly appreciated
    Dec 2013
    5717
    Re: Crusader M series CRT to LCD conversion
    It looks like there used to be a bolt in kit available, but no longer. https://www.ebay.com/p/Replace-CRT-A...d=252327720872
    There is some reference on the internet to a Jamma board for game CRTs being adapted. I suspect a direct connection is not possible. Personally I would rip out the antique Anilam controller and replace it with a Centroid or equivalent system.
    Jim Dawson
    Sandy, Oregon, USA
  1. anilam crusader series m help
    By fattrobb89 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-12-2016, 05:35 PM
  2. Colchester CNC with Crusader II conversion
    By Dave1200 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-22-2011, 01:53 AM
  3. help with Crusader M on brigeport series 1
    By hotrodhairy in forum Bridgeport / Hardinge Mills
    Last Post: 11-01-2011, 08:00 PM
  4. Animal Crusader M conversion to Crusader L?
    By Hythos in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-24-2009, 05:57 PM
  5. Anilam Crusader Series M
    By Maurice in forum Community Club House
    Last Post: 08-07-2008, 08:57 PM
