586,043 active members*
3,761 visitors online*
    Jan 2011
    129
    Need help, servo humming
    I have a Shizoka B3V milling machine that I have updated the controls and using Mach3.
    I retained the original Fanuc servo motors and encoders. The drives are from CNCdrives, model # DG4S-08020 .
    I have a warp9 ESS motion control board. I am using a CNC4PC C62 breakout board.
    I used the CNCDRIVES tuning stick to tune the servos.
    Within Mach3 I turned XY&Z axes to the same speed and velocity, etc. The Y&Z axes operate smooth and quiet. For some reason the X axis runs pretty smooth but is not quiet. There is a humming/resonating/vibration with the servo motor. If I hit the reset button the humming goes away. But the next time I use the X axis it returns.
    Anybody have any suggestions on tuning my X axis?
    Chuck
    Dec 2013
    5717
    Re: Need help, servo humming
    Maybe reduce the proportional gain a bit?
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2011
    129
    Not being real familiar with this subject, is there a simple way to explain how to do this with the system I have?
    Dec 2013
    5717
    I'm not familiar with that system either, but this can normally be accomplished using the tuning software provided by the drive manufacturer. Many systems have both auto-tuning and also allow you to make manual adjustments via the software.
    Look at the Setting up the Controller, PID tuning page in the tuning manual. Looks like you can manually enter a number from the setup software. Proportional gain would be the Ap parameter.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2011
    129
    Thanks Jim, I just noticed your post I will give that a try when I get some extra time.
    Chuck
  1. Mazak humming servo at idle
    By gusf in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-21-2017, 08:23 PM
  2. Motor Humming Noise?
    By Dman in forum Hobbycnc (Products)
    Last Post: 11-10-2008, 01:03 AM
  3. motors Humming and growling sometimes
    By artform in forum Xylotex
    Last Post: 09-07-2008, 02:53 AM
  4. g320's and a humming servo...
    By h_2_o in forum Gecko Drives
    Last Post: 12-01-2006, 07:21 AM
  5. Y axis humming on VF-1
    By Loading in forum Haas Mills
    Last Post: 08-28-2006, 12:31 AM
