586,058 active members*
3,483 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Vfd YL620-a initial setup
Results 1 to 13 of 13
    Hello guys..im building my first cnc router and im a bit confused with the vfd format. Most of the threads ive read and vids ive watched show changes made to the PD parameters...
    When i powered my vfd for the first time my format is different..it displays P00.00?
    Im using the 2.2kw square air cooled spindle. 220v and 400hz...was wondering if anyone has a list of parameter settings for this particular setup? Thanks for your time..
    15362
    Re: Vfd YL620-a initial setup
    Quote Originally Posted by Terryble24 View Post
    You may have to make some changes but should get you started, you may have to increase the minimum speed Frequency is you get over heating
    Huajiang VF Drive
    YL 600/620 220 2.2Kw
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P06.01=8 ( Acceleration Adjustable )
    P06.02=8 ( Deceleration Adjustable )
    P0700=400
    P07.08=0
    P11.01=220
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220
    Mactec54
    Huajiang VF Drive
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P0700=400
    P07.08=0
    P11.01=220
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220
    Thank you mactec54!
    Thank you mactec54!
    Hi mactec54. Thank you for the help so far. Im still having issues setting up the yl620-a. Youve forwarded me some initial settings...but when i got to parameter 1101 im only able to enter a value from 0-3, but your initial settings want me to input 220?
    Have i done something wrong, or might there be an error in the initial settins list?
    Im running it 220v with a 2.2kw air-cooled spindle.
    I think i should do a factory reset to be sure the parameters are correctly entered before i go any farther.
    Pls help me reset and replace the parameters...
    15362
    You should not have to do a reset just post where you have a problem and I may be able to help, there manuals are not very good at explaining the different fuctions
    You may find some of these can be left as 0= not activated ( 1 ) 110v ( 2 ) 220 ( 3 ) 380v
    Your model has 0 / 1 / 2 / 3 for some of the Parameter settings if not sure just leave it at 0 which is deactivated
    Mactec54
    Thank you sir!
    Hye there..
    Just wanna know, do u still need help for the parameter 620a?
    hello hafizi5299...still not complete unfortunately, havent powered it all up yet, i will post when its closer...
    Oct 2019
    I found this thread googling around for help with my recent YL620-A purchase. I'm trying to figure out how to do the equivalent of 'RUN' and 'STOP' from remote. Any help would be much appreciated.
    hello again guys. Due to this covid19 issue, ive had lots of time to work on my creation! I now seem to have an issue with my VFD (yl620-a). i powered it up on the bench many months ago, with mactec54's help, and no issues at the time. now that i have the VFD and spindle (2.2kw 400hz, 2400rpm) wired, i get an "er.01". This is an over-voltage alarm. Ive disconnected the spindle and have the same alarm. Ive done a factory reset on the VFD and went through the parameters again, adjusting to mactec54's recommendations, but still get the same alarm? Any idea what might be the problem?
    Nov 2020
    Hi Terryble24
    Did you manage to get the VFD sorted?
    Allan
    Apr 2016
    Hi. Mine also same model. But spindle is 8.5A. so I should change P0012 to 8.5A
    One more thing when I connect the wire to the spindle connector there are sparks at the connector when I increase the speed of spindle. I have not done any factory reset.
    Why is it that so.
    Huajiang VF Drive
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P0700=400
    P07.08=0
    P11.01=220
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220[/QUOTE]
    15362
    Quote Originally Posted by danishyj View Post
    Why is it that so.
    Huajiang VF Drive
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P0700=400
    P07.08=0
    P11.01=220
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220
    [/QUOTE]
    Sounds like bad wiring of the Plug, Check that the wires are not shorting against each other take some photos as this is not safe
    Mactec54
  1. Replies: 1
    Last Post: 10-19-2017, 12:48 PM
  2. Noob in need of help on initial setup
    By DylanG0704 in forum Mach Software (ArtSoft software)
    Last Post: 12-12-2015, 10:05 PM
  3. Initial setup of used tormach?
    By widget_maker in forum Tormach Personal CNC Mill
    Last Post: 03-08-2014, 12:36 AM
  4. Newbie Q regarding initial setup
    By czralv in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-12-2013, 03:10 AM
  5. Help in initial setup.
    By hjl4 in forum Viper Servo drives
    Last Post: 01-18-2011, 11:20 AM
