586,068 active members*
3,706 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > CNC Shaft Couplings, Whats out there?
    Jun 2018
    9
    Question CNC Shaft Couplings, Whats out there?
    Hey Guys,
    Just stumbled across this site and oh boy what a find! I have been drafting up some designs for a CNC over the past couple months, slowly researching each component of a CNC, but there is one thing that is still a little unclear to me. If I were to go with a threaded drive CNC what kind of shaft coupler should I use? If I were to use a NEMA 34 and a 16mm threaded rod what coupler would be robust enough to handle all that torque. I see some online but they do not look to convincing like this one https://www.vxb.com/D40-L66-14mm-to-...SABEgJV8PD_BwE. Has anyone had any experience with these and or what are you guys doing?
    Thanks in advance!!!
    All the best,
    DMC
    Apr 2004
    5737
    Re: CNC Shaft Couplings, Whats out there?
    I haven't used that particular brand, but that looks like a good coupler to me. I certainly don't see a NEMA 34 motor breaking it, if that's what you're worried about. The usual thing that causes jaw-coupler failure is slippage; either the set screw vibrates loose, or it starts cutting a groove in the shaft so it can wiggle around. The latter problem won't happen with the coupler you've linked to, since it's a clamp-style device that doesn't rely on a set screw directly contacting the shaft. To combat slippage, use a reversible thread sealer on the tightening screw.
    I'm not sure which 16mm threaded rod you're talking about using, but don't use the regular "all-thread" from the hardware store. An acme screw works much better as a leadscrew, if you don't want to spring for precision ball screws.
    Andrew Werby
    Website
    Feb 2009
    6028
    Nov 2012
    1267
    Quote Originally Posted by umfan110 View Post
    I use that kind of couplers, they work fine. They actually made my machine more quiet compared to "spiral cut" couplers.
  1. Taig motor shaft couplings
    By adonai in forum Taig Mills / Lathes
    Last Post: 06-16-2014, 10:35 AM
  2. Helical Beam Shaft Couplings
    By Techbuilder in forum Linear and Rotary Motion
    Last Post: 04-21-2010, 01:12 PM
  3. Flexible Shaft Couplings; where to buy?
    By boyvox in forum DIY CNC Router Table Machines
    Last Post: 04-13-2006, 09:37 PM
  4. mounting flexible couplings to 17mm shaft
    By cowanrg in forum MetalWork Discussion
    Last Post: 04-11-2005, 06:40 AM
  5. Shaft couplings??
    By Lanny in forum DIY CNC Router Table Machines
    Last Post: 07-10-2003, 12:29 PM
