586,950 active members*
2,671 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Post Processor Modification
Results 1 to 13 of 13
Hybrid View
    Apr 2013
    70
    Smile Post Processor Modification
    Is there a way to modify the PP to add the material that is selected to the code? I am using a modified PP for Haas. I tried this to no avail.
    2. Start of file standard
    "(PROGRAM NAME - ",prog_name,")"
    "(POST - ",machine_make,machine_model,")"
    "(DATE - ",output_date,")"
    "(TIME - ",output_time,")"
    "(MATERIAL - ",output_material,")"
    Just wondering if it's possible. :0
    Re: Post Processor Modification
    Use material_comment
    Outputs the defined material as a string.
    API:
    string MILLTURN_GetMaterialComment()
    Apr 2013
    70
    I have tried cutting and pasting several different ways what you suggested, but it still doesn't post material. If it makes a difference I am using V27 build 9600. Simple script I can muddle through anything complicated I get overwhelmed.
    I'm sorry,
    seem with V27 doesn't work but with V31 works fine.
    I haven't V27 and related documentation to try....
    With V31 I've changed my post adding:
    Code:
    0. File header
    	comment_start," ==                             == ",comment_end
    	comment_start," ==    Created for RosettaCNC   == ",comment_end
    	comment_start," ==      by BobCAD-CAM v31      == ",comment_end
    	comment_start," ==       5 Axis Mill - v1      == ",comment_end
    	comment_start," == Table-Table AxCz - RTCP ON  == ",comment_end
    	default_add_spaces
    	"O",prog_n
    	force_no_add_spaces
    	"; === PROGRAM INFO ==="
    	"; NAME: ",prog_name
    	"; POST: ",machine_make
    	"; MACH: ",machine_model
    	"; DATE: ",output_date
    	"; TIME: ",output_time
    	"; MATL: ",material_comment
    	"; === TOOLS INFO ==="
    	default_add_spaces
    	output_tool_list
    	user_comment_1
    	user_comment_2
    	user_comment_3
    	user_comment_4
    	user_comment_5
    	user_comment_6
    	user_comment_7
    	user_comment_8
    	user_comment_9
    	user_comment_10
    	user_comment_11
    	user_comment_12
    	user_comment_13
    	user_comment_14
    	user_comment_15
    and output gcode is:
    Code:
    O0100
    ; NAME: SWARF EXAMPLE 1.NGC
    ; POST: BC_TABLE_TABLE
    ; MACH: GENERIC FANUC
    ; DATE: TUE. 07/02/2019
    ; TIME: 10:11PM
    ; MATL: Carbon Steel 1018 - Plain (100-125 HB)
    (MTOOL T1 S1 D0.5 C0. A0. H3.)
    ; FIRST MACHINE SETUP - MACHINE SETUP - 1
    G00 G17 G20 G40 G49 G80 G90
    G54
    (FIRST CUT - FIRST TOOL)
    ; TOOL #1 0.5 1/2 FLAT ROUGH ENDMILL - STANDARD
    T1 M06
    G54
    C04.115
    A-20.374
    Variable names for use in scripting are different in different versions of BCC, ideally you need the variable list for the version you are working in, if a variable name is yielding an empty string it probably doesn't exist with that variable name in your version.
    Apr 2013
    70
    Tried V31 script as suggested and only the hard code without the variable posted. I suspect that magicniner is correct that, if there is a variable name to output material it is different in V27. I did a quick google search for the list and didn't find it. Is this list available anywhere. I like tinkering with scripts although I'm not very skilled at it. Either way, I appreciate the help!
    Take a look at this page if there is a equivalent variable: https://bobcad.com/components/webhel...elp_System.htm
    Apr 2013
    70
    Although there seems to be no variable for material output for V27, I do appreciate the link. Never knew list was right there waiting to be opened.
    l
    online help engine don't track in url the related page but you can watch the tree in image and discover all post-processor variables for V27
    Mill_Post_Variables is the "Legacy" info with V28, the other document is "current documentation" as supplied with V28
    Apr 2009
    3376
    Here's for V26
    Maybe some nuggets of info in here
    Attached Files Attached Files
    WOW there is a similar document also for V31 ?
    What the BCC documentation doesn't mention regarding Advanced Posting is that Check Boxes 1 to 24 are addressed as 0 to 23 in VB Script which can throw you a curve ball ;-)
  1. Post Processor Modification
    By zachf in forum BobCad-Cam
    Last Post: 03-21-2016, 03:30 PM
  2. Post processor modification for a 1990 SHINX war horse
    By Randomsledge in forum CNC Machining Centers
    Last Post: 03-05-2016, 07:56 AM
  3. X3 Post processor modification for Emcotronic tm02 mill
    By cf_tech in forum Post Processors for MC
    Last Post: 01-19-2013, 06:49 PM
  4. V8 Post Modification?
    By mjp in forum Post Processors for MC
    Last Post: 01-05-2009, 12:30 PM
  5. Post modification help?
    By bassn_07 in forum Esprit
    Last Post: 06-16-2008, 08:56 AM
