586,110 active members*
3,257 visitors online*
    Full Spectrum Laser 40W 4th Gen - Dead USB
    Hi - I have a 4th gen FSL laser. It appears that the mini USB connector is delaminating from the PCB (top board in pic). FSL is checking to see if they have a replacement board, but they've already mentioned a $750 cost for replacing this thing. Other than the dead board, the laser works well enough especially for its age.
    My questions:
    1) The board has a DB9 connector pinout exposed - does anyone know if I could use a USB --> Serial and connect to the DB9 pinouts to avoid the USB situation?
    2) Any recommendations on an alternative controller board to drive the laser instead? For giggles I picked up a cheap GRBL board on amazon that seems capable of running the stepper motors, but I'm not clear how (or if) I can use it to turn on the laser. Does anyone have a pinout explanation for the laser driver and what pins I need to talk via to drive the laser?
    3) If I can't figure out how to talk GRBL or eqiv to the laser controller, I was considering using the spindle on/off relay on the GRBL board and wire the relay around the physical "laser test" switch. I mostly cut w/ the laser instead of engrave - so I could use the power adjust pot on the machine to set laser power and the laser test button as on/off (except using the relay). Any reason this wouldn't/shouldn't work?
    Thanks!
    Sep 2005
    1740
    Re: Full Spectrum Laser 40W 4th Gen - Dead USB
    That board is special for FSL and will be the only one to run their software. A good electronics guy could solder a new connector on it, (much cheaper than $750). The DB9 is usually used for serial connection what does your owners manual say?
    Nov 2012
    492
    Sorry your in trouble with that crap company there rip off artist
  1. Full Spectrum Laser Dead again 4th time
    By Bigbird48 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-25-2013, 01:36 AM
  2. Full Spectrum Laser
    Last Post: 05-24-2013, 11:22 PM
  3. Full Spectrum Laser DEAD AGAIN
    Last Post: 05-20-2013, 07:46 PM
  4. Full Spectrum 40w Laser
    By oldguynewatthis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2013, 02:47 PM
  5. Full Spectrum laser
    By kycolt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-12-2010, 05:16 PM
