586,119 active members*
3,518 visitors online*
Results 1 to 9 of 9
    May 2004
    50
    Mazak 640M Error code 042
    Hi
    Can anyone help me please how to fix error code 042 on Mazak 640M?
    Sep 2017
    139
    Re: Mazak 640M Error code 042
    please share the complete alarm detail.(full line description from diagnosis alarms)
    May 2004
    50
    Quote Originally Posted by navinbhas View Post
    Hi here is it:
    42 SPINDLE PARAMETER MALFUNCTION
    Cause
    The parameters that have been transferred from the NC unit to the spindle amplifier during NC power-on are not correct.
    Action
    Require Mazak Technical Center or Technology Center to re-set the spindle parameters.
    Sep 2017
    139
    Quote Originally Posted by Tulak View Post
    Hi here is it:
    Cause
    Action
    There should be a data along with the alarm .
    42 SPINDLE PARAMETER MALFUNCTION (****,************,***). Check in the diagnosis screen.
    Also please check the 7 segment led status on power supply drive and spindle drive unit
    May 2004
    50
    sorry, here are
    42 SPINDLE PARAMETER MALFUNCTION ( , , ) C H M RedCause
    What was told me that spindle has one flashing light errors are 37 and F4.
    Sep 2017
    139
    sorry, here are
    Well can you confirm the led status on the power supply drive. MDS-CH-CV-*** DRIVE
    May 2004
    50
    navinbhas I like to say thank you very much for your time.
    here is: MDS-C1-SPH-185 that is flashing starts with 37 and F4
    Sep 2017
    139
    The status you mentioned is that on spindle drive unit. 37 can occur due to multiple issues
    1) if power supply drive is not working
    2) If the communication cable is faulty.
    3) If the communication out port (CN1B) of previous drive is faulty from which connection comes to CN1A of spindle drive unit
    4) If there is a parameter error in spindle axis.
    Hence to better understand, would need the LED status on other drive units.
    May 2004
    50
    Thanks for all help.
    We called Mazak service on this.
  1. mazak super turbo x510-error code 21, laser 009 cooling oil temp high
    By monday in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-20-2018, 07:17 AM
  2. Mazak Integrex 30 T Plus Control Tail Stock Movement Error Code 252
    By AutonomousAlex in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-18-2017, 09:31 PM
  3. Mazak FJV250 with 640M Control
    By 9566317 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-31-2017, 05:10 PM
  4. Mazak 640M control
    By Woody111 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-11-2011, 02:42 AM
  5. 640m g-code
    By lx545 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-02-2010, 03:21 PM
