586,072 active members*
4,439 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Bench Top CNC for cutting Copper/Brass sheet?
    Jul 2019
    So I've been looking at bench top CNC machines and was hoping I could get some reccomendations/advice from you guys.
    What I'm after is a small CNC that can cut through Copper, Sterling Silver and Brass sheets. I want to get back into making Jewlery but hand cutting the metal is killing my hands and it's too inaccurate.
    I have a good amount of experience with 3D printing but I'm still not quite sure what to look for in a CNC machine. I'd be fine building one from a kit or upgrading/modifing one if necessary but I cant really spend more then say 500 bucks on this.
    Would this product from Amazon work for my needs? Any other models you might suggest?
    SainSmart CNC $350.00 https://www.amazon.com/dp/B07Q27RT32..._fEIhDb81W9JJV
    Apr 2004
    5737
    Re: Bench Top CNC for cutting Copper/Brass sheet?
    Don't waste your money on a $500 CNC mill; it's just going to disappoint you. Instead, send the work out to someone with a waterjet or fiber-optic laser cutter; you should be able to get quite a bit of metal cut for $500. An alternative might be investing in pancake dies and punching out the pieces with a press. When you've sold all the jewelry you've made from those parts, you should have enough for a decent mill - or if not, keep going until you do.
    Andrew Werby
    Website
    Jul 2019
    Yeah, I thought of getting some basic shape punches but I wanted more flexibility than that in the shapes being cut out. What about sourceing and building/assembling all of the parts of a CNC on my own? I'm pretty confident in my build skills but I would need some basic instructions/guidance. Anyone know of anything like that?
  1. Anyone cutting 1mm brass sheet with laser?
    By davidmb in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-18-2015, 05:51 PM
  2. Cutting copper sheet?
    By bossfrog in forum Waterjet General Topics
    Last Post: 09-03-2011, 05:27 AM
  3. brass and copper
    By Millpremac in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-23-2011, 12:16 AM
  4. Plasma cutting copper sheet
    By JerseyBill in forum Hypertherm Plasma
    Last Post: 05-25-2010, 07:03 PM
  5. Copper, brass cutting parameter
    By rjambrek in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-31-2009, 11:20 PM
