586,058 active members*
4,424 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > cincinnate milling machine
Results 1 to 5 of 5
    Question cincinnate milling machine
    after machine alignment complete
    when i click start cycle for a program or MDI block
    machine doesn't work and give me a message
    " Axis Limits Off"
    could anyone help me for that
    Re: cincinnate milling machine
    Quote Originally Posted by ashrafhosni View Post
    " Axis Limits Off"
    The limit switch has broken and not working?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Quote Originally Posted by cncmakers001 View Post
    thanks for your reply
    i'll check all limit switches (+X, -X, +Y, -Y, +Z, -Z)
    Dec 2006
    584
    What machine is it and what control do you have on it??? More info would be helpful!!!!
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    i have solved my problem
    i found all spindle switches is cut-off and reconnect all again
    after that my machine is running in a good case
  1. Milling a plastic with a CNC 770 milling machine
    By Edmond Young in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-12-2013, 02:55 PM
  2. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
  3. CINCINNATE HORIZONTAL MACHINING CENTER MODEL AT
    By r.2.d.2 in forum Cincinnati CNC
    Last Post: 02-13-2010, 01:56 AM
