Part Description: This is a non-structural, decorative, carbon fiber plate. It has precise counter-sink holes for flat head bolts and not as precise beveling for decorative holes. Please specify whether your quote is for solid-core carbon fiber or other types of cores. We would prefer solid-core (for the look of the cross section) but would consider alternative cores depending on cost.
Material: 2mm, decorative grade (no visible flaws), 2x2 twill, woven, double-sided high-gloss carbon fiber plate
Tolerance: 0.005"
Finishing: outer edges sanded smooth
Quantity: 1-3 prototypes, 50 pcs. initial order. This will be an ongoing project with increasing quantities
Time Frame: Prototype - June 8-15 Initial Order - June 22-29
Please PM for the DXF file.
Thank you,
Chris Considine
