I scavenged motors from printer this past summer and I am finally starting to build the mechanics of the machine.
My plan is to use 3/8"-16 allthread with these 80 oz./in. steppers. I am using Bosch (like 80/20) extrusions with UHMWV insets as the linear bearing material. The extrusions have a very small 0.8mm ridge on either side of the slot in which the inserts will ride which will reduce the surface contact area and frinction (I hope!).
The base frame is welded 2"x3"x0.250" steel and an aluminum moving gantry. I can get aluminum plate for $4/lb from a local surplus dealer, which is prenty spendy for scrap if you ask me.
Machine capacity will be about 36"x33"x5" or so. Yes, I know it will be very slow but I have way more time than money right now. This a home cookin' project ala Chuck Knight who inspired me to build one.
Here is a pic of the plan as of tonight. Let me know if I am starting off in the wrong direction here on the capacity and wimpy motors.
Eldon.
