Syil first machines around 50~70 use old optical switch.which have quality problem.the switch can not defend on oil/water.so very easy broken,so many complain make us change new one.
that is why the Y axis distance compare old one have a little shorter.but we never use different kind ballscrew.all our ballscrew was same specifictioins.
also right now.we use 2 postion control for the switch on Y,and X axis.
yes,we consider use short ballscrew.or use single nut,but we check and have a results that it is not every sieg X3 bottom have same casting,..
i mean if descent of bottom too parallel,the Y axis distance also will be short.
single nut we consider the backlash,so still not confrim to instead it.
we must wait for single nut ballscrew past the test,then can replace it in future production.
Mr mike,Richard will coming to UK in this month to help us dealer in UK.i think if they have time will going to visit you.
anyway,this issue have been in my desk...
Xushuo
Syil china.
Direction,Commitment,Follow through
