586,065 active members*
4,842 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Setting up a Wabeco F1200C for CNC
    Jul 2019
    Hi gurus,
    I've been searching the interweb for good answers to my newbie question but haven't really found one. The question is this:
    I have a Wabeco mill with 3 stepper motors for x, y and z. These motors have one 9-pin RS232 plug each. As I understand it what I now need to get is a motion controller that accepts these plugs and further connects to my PC running Mach4. But so far I haven't found any motion controllers with 9-pin RS232 input.
    Can I convert the 9-pin plugs into USB and get a USB motion controller or does anyone have recommendations for how to proceed with my current plugs?
    Your help would be highly appreciated!
    Best regards,
    Stian
    Mar 2016
    6
    These are not serial plugs, they are simply connectors - you just need to open then up to see which pins are connected to which wire in the stepper. once youve done this - any stepper driver will work (current requirements allowing) - You just need to get corresponding sockets to make an adaptor cable if you want to keep the existing plugs.
