586,042 active members*
3,717 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Can’t turn on axis (after turn off machine during G-code)
    1. I pressed the button Home, - to home all axis (see file HOME_Axis.c). Machine start to go home, and during this I turned off the power.
    2. After 15 sec. I turn on the power. But in the screen of KmotionCNC all my axis are yellow.
    3. I restart computer and machine, in the screen of KmotionCNC all my axis are still yellow.
    4. In the screen of Kmotion > Axis, I found that axis 0, 1, 2, 3 are NOT Enable - somewhat unchek the boxes. Trying Enable axis, - but program don’t allow me to do this (it unchecks the box). But it allows me to Enable other axis 4, 5, 6, 7 - I don’t use these axis.
    5. I download in the Flash User Memory the file – see InitKStep4Axis.c. It doesn’t help, – after restarting machine, all axis are yellow, and in the menu Kmotion > Axis, I can’t Enable axis.
    How to Enable axis 0, 1, 2, 3? Why program don’t allow me to do this (it unchecks the boxes)?
    May 2006
    4045
    Re: Can’t turn on axis (after turn off machine during G-code)
    Hi RuslanRobot,
    Both programs have a loop disabling axes 0-3 if virtual bit 1024 (ESTOP) is not 1. See a fragment of your code below:
    Code:
    #define ESTOP_BIT 1028
    		// if ESTOP present disable any enabled Axis ??
    		if (ReadBit(ESTOP_BIT)!=1)                  // ÈÍÂÅÐÒÈÐÎÂÀÒÜ ÑÈÃÍÀË
    			if (ch0->Enable) DisableAxis(0);  // axis still enabled?  - Disable it
    			if (ch1->Enable) DisableAxis(1);  // axis still enabled?  - Disable it
    			if (ch2->Enable) DisableAxis(2);  // axis still enabled?  - Disable it
    			if (ch3->Enable) DisableAxis(3);  // axis still enabled?  - Disable it
    Bit 1024 (ESTOP) is Konnect Input 0.
    Is ESTOP on?
    TK
    http://dynomotion.com
    Yes!!!!
    I am idiot. I tried to make Kflop work while ESTOP is on.....
    Everything is work.
    Thank you very much!
    May 2006
    4045
    Ha ha. Thanks for taking the time to post back.
    TK
  1. Problem in machining of 5 axis in turn-mill machine
    By sarali in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-01-2019, 10:24 AM
  2. Replies: 1
    Last Post: 06-04-2018, 01:21 PM
  3. Replies: 0
    Last Post: 04-01-2016, 07:55 PM
  4. c axis feed rate on a turn /mill machine
    By bike in forum G-Code Programing
    Last Post: 09-30-2008, 12:57 AM
