586,042 active members*
3,718 visitors online*
IndustryArena Forum > CNC Electronics > DeskCNC Controller Board > DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller
    May 2006
    12
    yesterday I started testing a setup with DeskCNC 2nd. generation controller and HobbyCNC Pro 3-axes controller. Have the HobbyCNC 305OZ/in steppers for all tree axes. Does anyone have the same setup? I need to set the acceleration Ramp for the system...
    Feb 2005
    78
    Acceleraton settings
    Hi maycom,
    The acceleration settings are done mostly by trial and error, it is also possible to use a spread sheet to calculate the .acc file which will allow you to modify the profile to your hearts content. Just save as a text file and then load it under the Acc. settings menu.
    Regards,
    Greg
    www.cncdirect.co.za
  1. DeskCNC controller output current?
    By kolokithas in forum DeskCNC Controller Board
    Last Post: 09-27-2006, 12:10 AM
  2. Deskcnc users, what CAM software are you using with this controller?
    By Idle hands in forum DeskCNC Controller Board
    Last Post: 05-06-2006, 07:00 PM
  3. DeskCNC Controller and Xylotex
    By WarrenW in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-30-2005, 07:06 PM
  4. DeskCNC Controller/driver
    By rogerbureau in forum DeskCNC Controller Board
    Last Post: 01-18-2005, 09:30 AM
  5. 2nd generation DeskCNC controller now shipping
    By imserv in forum News Announcements
    Last Post: 10-01-2004, 12:22 PM
