Re: CNC kit purchased - I have electrical questions.
Hi
The motors should work fine. As stated the inductance is a bit high. This will reduce the top speed of the stepper motor. If you’re machine uses 5mm pitch ballscrews then stepper speed is probably not as issue.
The motors may get a little warmer due to the higher inductance but again it shouldn’t be an issue.
Personally I’d go ahead and use it now that you’ve purchased it.
Cheers
Peter.
Sent from my iPhone using Tapatalk Pro
Homann Designs - http://www.homanndesigns.com/store
