586,069 active members*
3,808 visitors online*
Results 1 to 8 of 8
    Aug 2011
    419
    meaning of SBP
    Hi
    Who knows, what is the long form of SBP?
    is it System Bios Program ?
    "Imagination is more important than knowledge."
    Apr 2004
    5737
    Re: meaning of SBP
    Shop Bot Program
    Andrew Werby
    Website
    Jun 2018
    362
    Re: meaning of SBP
    Acronyms have many interpretations, it depends on the subject and context.
    What is the context to which this applies?
    Aug 2011
    419
    Quote Originally Posted by he1957 View Post
    It seems when booting okuma cnc and some errors occurs
    Aug 2011
    419
    Re: meaning of SBP
    maybe SBP Monitor is Software, Boards and Processors Monitor
    Apr 2006
    111
    Re: meaning of SBP
    SBP: System Boot Program/Process
    Apr 2009
    1262
    Re: meaning of SBP
    I've heard system boot process as well.
    Usually means Something Bad Popping up as an alarm... ;-)
    Most times it's a communication issue of some sort but may also indicate boards going bad.
    Best regards,
    Experience is what you get just after you needed it.
    Apr 2006
    111
    Re: meaning of SBP
    SBP is in EPROM of MB not in MEM board. The function of SBP is same to BIOS of computer.
    anybody can share with me EPROM image in MB of OSP7000M?
    thank you very much.
  1. Meaning of N in load max spec
    By infomatrix in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 07-24-2013, 03:03 AM
  2. Replies: 2
    Last Post: 07-08-2011, 03:03 PM
  3. G201X LED color and meaning.
    By curriergroh in forum Gecko Drives
    Last Post: 04-13-2011, 02:28 PM
  4. DMU 125P, meaning of M51 code
    By metus in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-20-2009, 01:40 PM
  5. Meaning of G28?
    By kotten1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-07-2008, 11:59 PM
