586,068 active members*
4,239 visitors online*
Thread: Losing steps
Results 1 to 15 of 15
    May 2009
    327
    Losing steps
    I have a fresh new hell. My mill is starting to not go where it is supposed to. This has happened numerous times now. Some of the symptoms I am having is that the PDB display sometimes gets dim. I also have had the smoothstepper complain that it was overloaded. I am thinking maybe power supply? Any ideas?
    -Keith
    Jul 2011
    400
    Re: Losing steps
    Which VFD do you have? When I first got my mill I had the C300 vfd. I had issues with the smooth stepper. I don't remember the exact message but something like out of data. I also had trouble with the power draw bar. The display would show random gibberish characters and lock up. Novakon determined that the problem was probably electrical noise from the VFD. They sent me a GS2 VFD. The two issues I mentioned went away and did not return. If you already have a GS2 maybe check the connections? Make sure the wiring is tight as it can be a source of errors.
    I have since switched to an Acorn control and I'm currently testing it.
    May 2009
    327
    Re: Losing steps
    Thanks man. I will check it out but it worked fine for 5 years (well 2 with the smoothstepper). I did swap out my y axis motor with a new one. maybe I will switch back.
    Jul 2011
    400
    Re: Losing steps
    Any update on this? I think you were luckier than me. I had random issues with Mach 3 the entire time. At first because I was doing one offs I thought the problem was with me. When I started doing multiple part runs I found out that the issue was with Mach 3. Check for a loose coupling on the newly installed motor.
    Sep 2005
    1740
    Re: Losing steps
    Quote Originally Posted by upnorth View Post
    Do yourself a favor, go to either UNCNC or Mach4.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Jan 2016
    386
    Re: Losing steps
    Quote Originally Posted by wmgeorge View Post
    Don't forget PathPilot or LinuxCNC.
    Jun 2015
    943
    Re: Losing steps
    UCCNC is more modern and superior to mach3.
    Jul 2011
    400
    Re: Losing steps
    I already ditched Mach on the milling machine. I installed an Acorn. Its currently undergoing testing. I may try Mach 3 on a lathe I have. I have quite a bit of money invested in hardware that supports mach3. I would hate to toss out 2 perfectly good mother boards.
    Apr 2016
    841
    Re: Losing steps
    FWIW, if your hardware works with Mach3, it should work with Mach4. No need to toss them out. Warp9 has good setup instructions for Mach4 on their site.
    Jun 2015
    943
    Re: Losing steps
    If you using these controllers then they work with uccnc, mach3 and mach4, you can switch software any time you want.
    CNCdrive - motion controls
    May 2009
    327
    Re: Losing steps
    OK so an update. Mill is dead in the water. Will start up but PDB is dark, can't communicate with the ESS. I have so much work to do and my mill won't stop breaking. Does the ESS and bob work off the computer power supply? What about the PDB?
    Jan 2016
    386
    Re: Losing steps
    Try messaging Ray. He designed the PDB. Any help from John?
    Jul 2011
    400
    Re: Losing steps
    Well good news.You were posting while I was writing a reply. One of the great things about these small cnc machines is they are cheap and easy to fix. If it was a Haas or something you would probably be looking at a $5k repair bill to get it going again.
    May 2009
    327
    Re: Losing steps
    OK so I talked to John and he gave me some stuff to test. As soon as I moved one of the wires out of the PS everything came back on. Wiggled it and things went haywire a bit. New power supply and I am back in business! 3 hours of cutting with no problems. Maybe it is me just hoping but the mill seems to be cutting better than ever.
    Thanks everybody and especially John!
    Jul 2011
    400
    Re: Losing steps
    Have you checked for obvious loose connections? I would remove and reseat every connector on there. Maybe swap the power connector on the breakout board to another one on the power supply if one is available. They power drawbar does get power (5 VDC) from the motherboard. Likely the smoothstepper gets its power from the same source. You could easily temporarily wire in another computer power supply. To me that seems like the likely problem. Check the connections first. Maybe you have a bad break out board also. If it turns out the break out board is bad I removed one recently and replaced it with an acorn. I would sell it if its needed.
  1. Losing Steps Somehow
    By kjking in forum Machines running Mach Software
    Last Post: 06-29-2019, 09:44 PM
  2. Losing Steps
    By antennas4u in forum Australia, New Zealand Club House
    Last Post: 06-28-2015, 05:53 AM
  3. NEED HELP!!! LOSING STEPS
    By lukas0001 in forum Stepper Motors / Drives
    Last Post: 03-09-2015, 11:12 PM
  4. Please Help with CNC losing steps
    By mendez in forum DIY CNC Router Table Machines
    Last Post: 03-06-2010, 09:04 AM
  5. Losing steps in Z - need help
    By zeeway in forum DIY CNC Router Table Machines
    Last Post: 02-13-2010, 02:51 PM
