586,069 active members*
3,691 visitors online*
    Aug 2012
    13
    Sieg X3 - Erratic Spindle Speed
    My X3 has developed very erratic stop/start motion at low motor speed settings and has no power to do any work. Opinions - motor, control board or speed control potentiometer?
    Aug 2005
    1094
    Re: Sieg X3 - Erratic Spindle Speed
    If it is DC motor with brushes, check the condition of the brushes by removing them and have a look. They may be worn or dirty.
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
    Nov 2005
    222
    You may find some useful info at the link below on the trouble shooting page. Although checking the motor brushes as phomann said is the first thing I would do.
    www.olduhfguy.com
    May 2015
    686
    I've had this problem with a SX3. unplugging connectors and wiping down with Innox fixed mine.
    Rod Webster
    www.vehiclemods.net.au
    Aug 2012
    13
    Thanks all for your replies. I have checked the brushes and they seemed fine but the commutator looks a bit ordinary. Its like the machine has a broken wire or similar with stop-start-stop-start action and it seemed to happen all of a sudden. I guess I'll check the connections and pull the motor and get a little more serious. I have a bit on my plate at the moment and was just trying to 'short circuit' the repair as its annoying not having the drill for quick little jobs. Thanks again.
  1. Syil X3 Erratic Spindle Speed with Mach
    By reithguitars in forum Syil Products
    Last Post: 01-21-2017, 08:43 AM
  2. Fadal EMC Spindle Speed Erratic
    By jmcalpin in forum Fadal
    Last Post: 02-03-2015, 10:30 PM
  3. Sieg SX2 spindle speed
    By Hoffies in forum Benchtop Machines
    Last Post: 09-28-2013, 05:29 PM
  4. Erratic Spindle Speed
    By groundhog719 in forum Syil Products
    Last Post: 06-15-2011, 02:54 PM
  5. Spindle speed for Sieg conversion
    By rcotteleer in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2006, 07:29 AM
