586,108 active members*
3,100 visitors online*
    Scaling problem
    Hey everyone!
    I sure do hope someone could help me with my problem, I am a total beginner after all. I just built my cnc routing machine. I am (trying to) work with Aspire and Universal G-code Sender. So the problem I have is that I draw a simple shape such as a square to be 50mm by 80mm and then the machine creates a square like 3mm by 2mm. I do not understand where the problem lies because I have already calibrated the machine in the x, y and z directions. Any help will be appreciated greatly!
    Many Thanks
    Kevin
    Re: Scaling problem
    Sounds like you have an inch-mm conversion issue between Aspire and UGS.
  1. CNC6040 XYZ scaling problem
    By dobrun2004 in forum Chinese Machines
    Last Post: 08-07-2016, 12:38 PM
  2. Scaling mismatch problem
    By gyzoli in forum Uncategorised MetalWorking Machines
    Last Post: 10-18-2015, 06:31 AM
  3. PCB Scaling problem
    By negativ3 in forum PCB milling
    Last Post: 07-24-2014, 08:06 PM
  4. Scaling problem
    By kentigens in forum LinuxCNC (formerly EMC2)
    Last Post: 03-24-2009, 02:34 PM
