586,119 active members*
3,619 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Meldas 64 control, dnc, memory, info..feeler vmc , fairfriend .
    Dec 2007
    118
    hi, I am looking for info on DNC or mem increase on an old Meldas 64 control.. Feeler VF1600 milling machine...
    Sep 2017
    139
    Re: Meldas 64 control, dnc, memory, info..feeler vmc , fairfriend .
    Meldas 64-B, 64S, there is no add on memory feature. There is cassette HR437 which helps, with add on memory but you need to check with Mitsubishi for the same.
    DNC parameters you would get in the feeler machine manual.
    Dec 2007
    118
    so far I found this...https://www.ebay.com/itm/haas-USB-FL....c100005.m1851
    also looking to dnc with easydnc,
  1. FV-800 Feeler MELDAS 520 wont change Mode after powerup?
    By BSXTECHLLC in forum Other Machine Topics
    Last Post: 06-22-2017, 09:37 PM
  2. Meldas 50 running on a Feeler FV1000-SE
    By casan in forum Mitsubishi controls
    Last Post: 08-22-2016, 02:47 PM
  3. Feeler DT0 with Mitsubishi Meldas M50 parameter loss.
    By dpelivan in forum DNC Problems and Solutions
    Last Post: 01-10-2012, 10:48 PM
  4. Ele diagram for feeler fv600 ,Meldas M-50
    By vishnusawant200 in forum Open Source CNC Machine Designs
    Last Post: 08-17-2010, 11:47 AM
