586,036 active members*
3,637 visitors online*
IndustryArena Forum > MetalWorking Machines > Smithy > Smithy CNC 1240 gear box conversion
    Oct 2006
    157
    Hello!
    I have an older CNC 1240 with 4 speed manual gear box.
    The only real problem I have had with the machine over the last 12 or 15 years is the gear box breaks the top speed gear (2700 RPM)
    I think some of the problem is when the motor turns on - there is no ramp up to RPM. It is just bang 2700.
    It is all solid shaft's together with a Key way.
    At minimum I am thinking of putting in a Love-Joy coupler to help dampen the engagement and it might be a little easier on the gears.
    But I think the ultimate fix would be to change it over to a belt drive.
    Has anyone ever done this ? There machine they came out after I bought min, was called the "Talon" I think . And it had a belt drive.
    But it was discontinued.
    The closest thing I can find available - that looks real similar is the Novakon "Torus Pro"
    It looks like I might be able to use some parts from them???
    What are your thoughts?
    All help appreciated.
    Oct 2006
    157
    Re: Smithy CNC 1240 gear box conversion
    Looks like im going to go ahead and do a belt conversion . This should be interesting.
    Sep 2005
    1740
    I have never had any machine with direct drive from the motor to the gear box. I think your on the right track, I wonder how other owners are dealing with it.
  1. NM200 same as Smithy 1240
    By newton009 in forum Smithy
    Last Post: 07-13-2019, 11:53 PM
  2. How much to pay for used Smithy 1240 CNC?
    By cowanrg in forum Smithy
    Last Post: 02-14-2015, 03:38 AM
  3. Anybody using a Smithy 1240 with mach3?
    By bones in forum Smithy
    Last Post: 03-22-2013, 04:19 PM
  4. Smithy 1240 cnc questions
    By nupeswv in forum Smithy
    Last Post: 11-05-2008, 06:03 PM
  5. Smithy 1240 or tomach?
    By petecul in forum Knee Vertical Mills
    Last Post: 04-25-2007, 01:57 AM
