586,068 active members*
4,515 visitors online*
Page 1 of 3 123
Results 1 to 20 of 51
    Mar 2014
    1131
    Let's build some ISO20 spindles
    Unfinished pull stud grippers.
    Sent from my MI 5s Plus using Tapatalk
    Mar 2014
    1131
    Re: Let's build some ISO20 spindles
    It took some time to finish the first gripper because I was busy with other things but here it is. Jaws made from ck45.
    Mar 2014
    1131
    And here I am on the design at the moment.
    Mar 2014
    1131
    What is the correct angle for ISO20 taper? I mean what the angle of the spindle taper should be?
    Jun 2007
    3891
    um. shoudlnt that have been the first step here?
    taper for ALL steep taper type tooling, regardless of size is 7 in 24.
    which means, your profile reference points for angle are are 3.5 units radially, 24 units axial. with an opening of 22.225mm (7/8") diametre.
    Mar 2014
    1131
    Soo, does that make 16,5943?
    Jun 2007
    3891
    i hope not. your tools will fall out.
    it should be half that per side.
    i assume you need the actual angle for manual lathe?
    Mar 2014
    1131
    Hi again,
    It's a CNC'ed lathe.
    According to my calculation the angle of the line is 188.29715° however, I just tried to cut the taper on aluminium but it is narrower on the large size so there is a little play on the small side. What did I miss?
    Aug 2019
    339
    AL is not cheap :/ Can we see your sketch's dim or part's pmi?
    Jun 2007
    3891
    al is cheap AF :P
    better to screw that up than A2
    this is also why you dont use angles. use the 7 in 24 measurements.
    difficult to know what has gone wrong, without knowing you use 7 in 24 to start (and not some rounded off angle)
    Aug 2019
    339
    Quote Originally Posted by ihavenofish View Post
    al is cheap AF :P
    haha true. To clarify my comment I would have done that rough fitting test with a cheap'er composite, wax or hell.. an old piece of wood maybe
    ps. please never tell my wife where are her ikea candles, she'll destroy me. She still wonders where they are
    Jun 2007
    3891
    you must work at one of the spindle factories ive talked to.....
    Aug 2019
    339
    ah. Nah at our spindle factory we use A4 size sheet of paper rolled between our fingers to dbl-check tapper angles. The sign-off engineers prefer that entertainment over having to click those 4 buttons out of that Microsoft Scientific calculator.
    Mar 2014
    1131
    atan(7/24) makes 16.2602047083 degrees so half of the angle is 8.13010235416. So my angle will be 188.13010235416
    I hope I'm good this time. Can you please confirm?
    By the way, I don't know if I could directly enter "arctan(7/24)" to the angle text field in SolidWorks. I'll give it a try.
    Aug 2019
    339
    Getting the same at my end, measured from centerline mind you. Both 3.5/12 & 7/24 checks out...
    If your CAD can't do math and arithmetic/operators it is not a CAD, its a scam
    Bet SW can do formulas better than most others anyway... you should be more than okay on that side
    Mar 2014
    1131
    Mar 2014
    1131
    Hi again,
    7/24 doesn't fit. There is still space in the small end of the taper. However I tried 8° 17' 50" and it appears to be the correct angle.
    Jun 2007
    3891
    O_o
    whats that in decimal?
    curious why it wouldn't match up. I was certain all those tapers were the same spec.
    Aug 2019
    339
    whats that in decimal?.
    8.2972°
    Jun 2007
    3891
    thats 7 in 24.....
    why cant kids math these days?
Page 1 of 3 123
  1. ISO20 or ISO30 Headstock For Taig
    By superchargerjim in forum Taig Mills / Lathes
    Last Post: 01-03-2019, 09:12 PM
  2. iso20 vs TTS
    By spacehitchhiker42 in forum Benchtop Machines
    Last Post: 08-25-2018, 05:27 AM
  3. ISO20 ATC spindle for Mills and Routers
    By dwalsh62 in forum News Announcements
    Last Post: 02-13-2014, 01:38 PM
  4. ISO20, ISO30, HSK 50 HSK 63????
    By 15mgtar in forum CNC Tooling
    Last Post: 08-21-2010, 02:25 PM
  5. Spindles de alta qualidade.High quality spindles.
    By Newtron in forum News Announcements
    Last Post: 09-21-2009, 08:33 PM
