586,110 active members*
3,372 visitors online*
    Feb 2016
    50
    MACH3 Homing Y/A Slaved axis together
    I have upgraded my breakout board with a USB MK6-V motion card. I'm having an issue that my dual driven gantry Y/A axis drives are not homing together like they were. I have them jogging and homing together as they did before. But after each makes their own home switch. They take turns on offsetting back. Which puts the gantry in a bend. I had this problem years ago but haven't figured what i did. I think the problem was fixed when I installed a 2010 screen set. Which I can still use.Is there a macro that may have gotten writen over? Also I noticed my homing all order has changed. Old order z/x/y. New order z/y/x. Not a big deal other than OCD.
    ThX
    Re: MACH3 Homing Y/A Slaved axis together
    Most likely, the chinese controller doesn't support slaved homing.
    Feb 2016
    50
    Yes it does appear so. After several days trying different settings and macro edits. The best= I've adjusted the debounce from 5 to 2. Even though this a mm setting and I run in inches. Their setting is 1-5 in the plug-in configuration. From seeing and DRO. 2-5 are in mm. If set to 1 it goes to 1". That shows a bad design from XHC. So to sum this up. Yes it does square the gantry. But puts a slight twist in alignment while doing so. In my case that little is ok with my machine. This $300 chinese motion card is not as good as my $30 chinese DDMMV2.1 Parallel board was for me.
  1. Homing with a slaved axis with mach 3
    By vtx1029 in forum DIY CNC Router Table Machines
    Last Post: 06-10-2017, 10:52 PM
  2. Mach3 Limit/Home issue with slaved axis
    By Dub_ in forum Machines running Mach Software
    Last Post: 11-29-2015, 06:16 PM
  3. Homing issue with slaved axis
    By hsgreer in forum Mach Software (ArtSoft software)
    Last Post: 06-04-2012, 05:08 AM
  4. Slaved stepper axis out of sync (Lag) Mach3
    By LazyMan in forum DIY CNC Router Table Machines
    Last Post: 12-30-2011, 01:53 AM
  5. G540 not homing a slaved axis
    By bcourson in forum Gecko Drives
    Last Post: 12-04-2009, 03:59 PM
