586,114 active members*
3,143 visitors online*
    Nov 2018
    CNCRP 4848 to 4896 Upgrade
    I have decided to embark on upgrading a mutant standard 4848 to a true* 4896. I hope this will not only help me but for future users. If you see something that is not correct or better parts please speak up.
    Once this is done i might have wasted more time and money than going with an upgrade kit from AvidCNC.
    My mutant 4848 is comprised of rack, pinion, gantry parts from CNCRP and a welded base frame without cross members. I will be using extrusions for the new 4896 base and reuse whatever exist to keep the cost down, your cost could be lower if you have a true 4848.
    DIY Parts
    All parts are listed as if a new base was to be made without reusing existing hardware (ill remove the extra parts for my personal b.o.m.)
    2 X 108" (Y Axis) 1545 profile 10' triple rail McMaster $234.98 X 2
    9 X 54” Cross members 1530 profile 10. 10' & 6' Duble rail McMaster $117.85 X 4 $60.04 X 1
    Nov 2018
    Re: CNCRP 4848 to 4896 Upgrade
    Seems one can't edit a post and this will probably break my intended post with all details. i hope to consolidate all this and have a mod clean it up.
  1. Finished CNCRP 4896 Pro
    By pinion in forum Avid CNC
    Last Post: 07-21-2016, 06:07 PM
  2. Replies: 44
    Last Post: 12-26-2015, 10:53 PM
  3. CNCRP 4848 Axis Slipping
    By sharob27 in forum Avid CNC
    Last Post: 06-30-2015, 12:48 AM
  4. CNCRP PRO 4848 NEMA 23
    By cstmwrks in forum Avid CNC
    Last Post: 06-27-2015, 07:59 PM
  5. CNCRP 4848 Prep.
    By tangeray in forum DIY CNC Router Table Machines
    Last Post: 08-04-2013, 11:44 PM
