586,416 active members*
3,527 visitors online*
    Unhappy Cutting MDF Wood with Laser CO2
    Hello ALL,
    I got a 600x400 Laser CO2 machine.
    I can cut out the mica 5mm, but I can't do that with MDF Wood 5.5mm.
    I had set Speed 15mm/s and amper 45.
    Please help me, (
    Jan 2008
    940
    Re: Cutting MDF Wood with Laser CO2
    What watt is your laser. 45 amps is way to high for most tubes. do you use air assist
    Jun 2019
    29
    What do you think are the chances the machine caught fire and burned down ttnc4plus?
    fixtureman1 has the right idea to check the air assist, on a machine that large, would be surprised if there wasn't one, my school's 60w laser was cutting worse than a 30w laser all because of a loose bowden tube connection. Otherwise, what are your settings?
    Oct 2019
    37
    Hello,
    We are manufacture of fiber optic or CO2 laser equipment in China,if you need any marker,cutter,clener,please do not hesitate to contact me.
    James
    whatspp:18600395818
    Email:[email protected]
    Oct 2019
    37
    what watt you take for the laser
  1. Laser wood model cutting – cutting a chair
    By Nolan Yang in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-22-2014, 07:17 AM
  2. Laser cutting wood
    By vmeek in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-03-2013, 10:06 AM
  3. Laser Wood Cutting
    By Autonow in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-08-2011, 02:09 PM
  4. Replies: 0
    Last Post: 08-15-2011, 03:08 AM
  5. which laser for wood cutting
    By colormecnc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-14-2007, 07:05 PM
