586,838 active members*
2,394 visitors online*
    Sep 2017
    15
    Tool Management on NLX2500/700
    Hey everyone,
    I am trying to get the Tool Life Counter to work on our NLX2500/700. I have done all the things that the Tool Management book tells you to do, Building the tool shapes, how there held in the machine, Tool numbers, Group numbers, how many times the tool can be used, and it still will not work. I have even tried to push the "Monitor Mode" button and still nothing. Is there a "G" code or "M" code that starts the Tool Life Counter like the G313 does for the Load Monitor system? If there is the books don't have it. It is so frustrating when you put so many hours in making all the tools and then putting them in the turret in the Tool Management page, plus the time in reading the books and it don't work. I have to be over looking something and I just can't find it.
    Sep 2017
    15
    Re: Tool Management on NLX2500/700
    Problem solved!!!
    Found that there is 2 parameters that have to change and then it worked.
  1. Tool Management in HSMAdvisor Tool Database
    By zero_divide in forum News Announcements
    Last Post: 12-07-2015, 06:01 AM
  2. Replies: 6
    Last Post: 06-27-2015, 10:04 PM
  3. NL2500 or NLX2500 tool clearances
    By Don18P in forum Mori Seiki lathes
    Last Post: 07-10-2012, 12:07 PM
  4. tool management
    By gucki in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-29-2012, 02:05 PM
  5. Renishaw tool offset / break probe and tool life management
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2010, 04:14 AM
