I'm new to this forum. We have Enshu mill with Fanuc OM series. One of the guys pressed reset and delete buttons together during power up and wiped all parameters. We had saved the parameters before. How can I reload them?
Loading Method by manualy
Switch ON the control, keep it in Emergency stop condition. Select the parameter page and enter the parameters manually one by one.
Load the Optional Parameters 900 series
Load the Axis parameters 8100, 8200,8300 series if it is Digital Drive
Switch OFF and Switch ON again
Select the Diagnosis Page
Load the Parameters of Timers, counters value in 300 & 400 series
Check any PC setting values supplied by machine tool builder Enter that values.
If you are having any Macro program in 9000 series that also to be entered if that is deleted.
Thanks for the reply. I manually loaded all the parameters. I'm getting alarm 580. I don't have 8th axis. How can I get rid of it. It still has not ready message.
H! check it again , may be you have input wrong bit by manual input ! always happen ! check it again
Check the Parameters Once again as told by Mr F. Sharifi.
