586,111 active members*
3,232 visitors online*
Results 1 to 6 of 6
    Feb 2009
    214
    cutting strategy
    in the 3 pics, one side I am going to remove the material from one side as shown with the tool path, then I am going to turn the piece 45 degrees and need to cut the small groves. how do I cut the grooves without cutting so much air?
    David L. Aery
    www.hooksolutions.com
    Re: cutting strategy
    Run the simulation and save the stock out as a solid model, import this as the stock for the next op.
    Feb 2009
    214
    Wow, thanks!
    I never would have thought of doing it that way.:wee::wee::wee:
    David L. Aery
    Feb 2009
    214
    ok I have 2 machine setups. In the pics the first setup the side is the top, then after it cuts the side I thought it would stop so I could re-position the part when it goes from one machine setup to the next but it did not. the simulation runs as it should.
    David L. Aery
    Quote Originally Posted by dlaery View Post
    You can manually edit and add in a stop command at the end of the code from the first setup.
    Alternatively post your two setups as separate programs.
    Feb 2009
    214
    ok, thanks, I'll try that.
    David L. Aery
  1. cant figure out a cutting strategy for this part
    By 1hander in forum Autodesk CAM
    Last Post: 05-25-2015, 10:01 AM
  2. Replies: 4
    Last Post: 04-06-2015, 09:37 AM
  3. Cutting Strategy for large Plywood Sheets
    By spooner777 in forum WoodWorking Topics
    Last Post: 09-08-2014, 09:32 PM
  4. What strategy to use here?
    By BTP in forum Mastercam
    Last Post: 04-19-2013, 04:58 PM
  5. Strategy
    By Pierre Phe in forum CNC Machine Related Electronics
    Last Post: 06-06-2003, 07:14 PM
