586,033 active members*
3,598 visitors online*
    OmniTech 1212 trouble
    Hello! I have some pressing questions about OmniTech's 1212 CNC machine. its just a simple 4'x4' cutting table with liquid cooled spindle, for those who are curious. The trouble I'm having is probably all software-based. You see, the installer version of Mach 3 that came on the files disk wouldn't run, so I just downloaded the program offline from Newfangled Solutions. Also, the included instructions weren't too clear, but I moved all of the files that I needed to into the Mach3 file directory. Despite all this, the program is still in demo mode, even though the (clearly outdated but the only one i have) video shows that somewhere in the process Mach3 becomes licensed. Any solutions?
    Also, it can control the machine, but not really. It jogs from the software on the laptop I have, but the y-axis jogs backwards. Maybe the sticker on the machine is on backwards? IDK, but I have tried going in to homes/limits and ticked the reverse box and nothing changes. Speaking of homes/limits, I think i have another issue there, too. When I press go to 0, the x and z axis move toward their (home switch? It's an electromagnet proximity switch) and then stop and that is that. The only axis that doesn't move towards its switch is the Y. Did I accidentally Ref All Home in the wrong spot? Also, when one of the axis triggers it's switch, it locks the axis up IN The Direction That I Need To Move It to get it Away from the switch. But, I can only jog it one way- the direction of the switch, even after resetting. The only way for my axes to escape the clutches of the cursed homing switches is to hit go to Z.
    Okay, final problem I promise. This should be Easy, though. There is a little brass disk connected to a curly telephone-esq wire. It can be taken out of its nesting spot and moved around on the machine. I have no idea what it is. or how to use it. Thoughts?
    To sum up my issues,
    --Y axis seems to be reversed, homes/limits doesn't change anything
    --Mach3 still in Demo after all files transferred
    --magnetic proximity switches lock up axis, only way to fix is GoTo zero
    --round brass disk on wire- What is it? How do I use it?
    Any and all help will mean wonders to me
    Mike
    Apr 2005
    304
    Re: OmniTech 1212 trouble
    Y axis: In Config/Ports and Pins - Motor Outputs, reverse Dir low active (if it is ticked untisk it or vice versa)
    You downloaded and installed Mach3 Demo. Limitation is 500 lines of G-code, and some others (can not remember). You should buy the licence and not to use "the provided pirated one".
    Proximity switches: Check in Piort and Pins - Input Signals that desired Home/Limit inputs are enabled and correct port/pin selected (Home and Limit switches could be "combined" i.e same switch can act as Home and Limit at the same time.)
    Round brass dosk: Touch sensor for setting Z0
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  1. Hardwood Speeds/Feeds - Omnitech Selexx
    By turindev in forum Commercial CNC Wood Routers
    Last Post: 06-05-2019, 12:52 AM
  2. OMNITECH 1530 / Syntec 6MB
    By matthewomeara in forum Post Processors for MC
    Last Post: 12-20-2018, 01:36 AM
  3. Texturing wood with Omnitech 1325 and Vectric Aspire
    By allencncrouter in forum Videos
    Last Post: 06-06-2018, 02:39 AM
  4. Omnitech sales representative?
    By dominique44 in forum Chinese Machines
    Last Post: 02-13-2016, 12:41 AM
  5. KL-1212 is on the way!
    By rosco in forum Automation Technology Products
    Last Post: 02-11-2010, 08:25 PM
