586,061 active members*
4,673 visitors online*
Results 1 to 6 of 6
    Oct 2012
    30
    Dunedin NZ smal job needed
    Hi
    Im in Dunedin NZ.
    Need a small job done. Ive got a aluminium solide tube around 32mm dia that I need taken down to 21mm
    Anybody out there please?
    Jun 2010
    4256
    Re: Dunedin NZ smal job needed
    A solide tube????
    32 mm down to 21 mm is a huge reduction, and a massive waste of aluminium too. I can't imagine a tube with such a wall thickness.
    You don't mention length either.
    Cheers
    Roger
    Oct 2012
    30
    Quote Originally Posted by RCaffin View Post
    A solide tube????
    Cheers
    Roger
    Yes a solid tube. its actually 26mms dia but needs to be 21.5 for the first 56mms. Length is 23cms. Your a bit far from NZ for such a small job Roger.
    waist aluminium isnt an issue when modifying . Its not gold
    Jul 2011
    400
    I think what Rcaffin was getting at is that tubes are hollow and not solid. You probably mean you have a round bar. Cutting down a tube the amount you mention would be a huge reduction. There would in most cases be no wall left. Cutting down a piece of round bar that amount is an easy job. I would gladly cut it down for you but I'm on the other side of the world.
    Oct 2012
    30
    ah well thats why I said solid. yep bar might have been a better description. When I lived in Europe there were dozens of people who would have done it localy. here in NZ , I cant find any
    I got a cnc, maybe i should get a lathe.]
    Jul 2011
    400
    Quote Originally Posted by dudz View Post
    I have a CNC mill and lathe. The lathe is not operational yet. I recently bought a manual lathe to go along with them. I thought there was no need for a manual lathe but I think now it will be a great addition. Its a pain not having one of the two machines. I'm sure someone will pop up in your area with a lathe.
  1. smal mechanical-only kit with 80mm spindle?
    By DIYedInTheWool in forum Chinese Machines
    Last Post: 10-21-2016, 10:21 PM
  2. Replies: 8
    Last Post: 08-21-2015, 07:43 AM
  3. [ADVICE NEEDED] Z-Axis not moving - CNC builder needed
    By baodogg in forum Australia, New Zealand Club House
    Last Post: 06-03-2014, 12:42 PM
  4. New Guy from Dunedin looking for Fagor post
    By Dazz88 in forum Australia, New Zealand Club House
    Last Post: 07-01-2008, 01:23 AM
  5. drawings end up way too smal
    By ranita in forum Mach Mill
    Last Post: 10-16-2007, 08:19 AM
