509,742 active members
4,115 visitors online
IndustryArena Forum > Machine Controllers Software and Solutions > UCCNC Control Software > How to configure a soft stop button - Not E-stop
Results 1 to 2 of 2
    Member
    Feb 2012
    123
    I have been trying to come up with a soft stop for a while now and the solution is not coming to me. Looking for ideas.
    I have UC300eth-UB1, UCCNC, DMM Dyn4 servos.
    I have wired the UB1 with a push-pull estop, charge pump, safety relay, and a contactor. The safety circuit works well and as expected.
    I have two momentary switches (on & stop). I use the on to set the safety relay and energize the contactor. Currently, I have the momentary stop wired in the e-stop circuit, so I can stop with out using the estop button.(even though it still performs the same function as killing the power)
    I want to use the enable inputs of the drives as well as the (WJ200 VFD) to create a soft stop, instead of killing the drives power every time I want to shutdown. I feel it would be better to have a controlled shutdown, but I am not coming up with a good solution. I could swap the momentary with a latching switch and wire to the UB1 inputs, but how do I connect the switched input with the needed output to open the drives enable circuit? Any input?
    Registered
    Jun 2015
    882
    Re: How to configure a soft stop button - Not E-stop
    You can add a stop function of the UCCNC in the input triggers.
    That attaches the stop function call to an input pin state.
    The stop function makes controlled stop.
  1. ESS with MB2: How to configure K1 to start/stop Spindle
    By Sterob in forum SmoothStepper USB Motion Control
    Last Post: 06-08-2018, 03:29 AM
  2. Limit Stop and Soft Stop MPC6515 and LaserCut5.3
    By JHamilton in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 10-22-2013, 03:19 PM
  3. E stop button
    By 85burban in forum Tree
    Last Post: 02-23-2012, 12:57 PM
  4. E-Stop Button
    By widgitmaster in forum General CNC Machine Related Electronics
    Last Post: 05-19-2008, 08:41 PM
  5. Help with e-stop button
    By Astroguy in forum Xylotex
    Last Post: 05-31-2007, 01:23 PM
