586,075 active members*
4,116 visitors online*
Results 1 to 3 of 3
    183
    steel coulmns loading
    Is there a table or calculations for figuring out how much weight a column can tolerate?
    Lets say 4' piece of 2" square tube 1/8" wall thickness, how much weight can be applied before it starts to deflect?
    Dec 2004
    86
    .0000000000000000000000001lb.
    Any load will deflect the beam, its just a matter of how much.
    May 2003
    550
    Look up Euler's Formula. Basically the critical buckling load (beyond elastic limit) for a vertical column is;
    Fcr=(ExIxPi^2)/L^2
    Where;
    Fcr=critical force or load,
    E=youngs modulus for material,
    I = area moment of inertia of the horizontal cross section
    L= column length
    note that critical load decreases with the square of the column length
    L used in the formula changes depending on how the ends of the column are terminated. There's a table somewhere but if the ends are clamped solid then L = 0.5 x actual length. If they're free to float it's 2.0 x actual length and various permutations in between.
  1. loading ballscrew nut
    By russell in forum DIY CNC Router Table Machines
    Last Post: 08-03-2011, 07:48 PM
  2. Loading Limit
    By martindugdale in forum CNC Machining Centers
    Last Post: 05-08-2007, 01:06 PM
  3. loading programs into dos
    By bkstout in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-13-2006, 03:05 AM
  4. re-loading ballscrews
    By marx911 in forum Uncategorised MetalWorking Machines
    Last Post: 09-04-2005, 06:19 AM
  5. Down/up loading offsets
    By JPann in forum DNC Problems and Solutions
    Last Post: 03-22-2004, 03:17 AM
