587,003 active members*
3,028 visitors online*
Thread: best plywood
Results 1 to 7 of 7
    Jun 2007
    best plywood
    Hi
    Does anyone have any good experience in laser cutting different plywood, and which type of ply would be the best to cut?
    cheers
    6855
    How many watts is your laser?
    Jun 2007
    100 watts, looking to cut 1.5mm thick ply
    Aug 2006
    Beamer I would think with a 100 watt laser you are going to be able to cut 1.5CM as for 1.5mm it should cut through that like butter!
    Apr 2007
    15
    You should have no problems with your set up, get as clean as wood as possible, knots cause issues because of the high density.
    I have cut 5/8 10 ply hard maple as fast as 75ipm with 400 watts.
    Brian
    www.precolaser.com
    Mar 2007
    19
    My source for good ply.
    www.aircraftspruce.com
    John
    Jul 2007
    78
    I only have 45 watts and have cut up to 6mm baltic birch with no problems.
    I tried to do 1/2" MDO and it took 3 passes and burned the edge.
  1. What Bits Do You use For Plywood?
    By Joe Petro in forum DIY CNC Router Table Machines
    Last Post: 02-24-2006, 09:07 PM
  2. Plywood and V Bearings
    By spalm in forum DIY CNC Router Table Machines
    Last Post: 12-09-2005, 03:12 PM
  3. Plywood as tooling?!?
    By DAB_Design in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-26-2005, 10:11 PM
  4. Spindle motor for plywood?
    By gizwiz in forum DIY CNC Router Table Machines
    Last Post: 02-28-2005, 03:54 AM
