586,612 active members*
3,653 visitors online*
Results 1 to 13 of 13
    May 2007
    49
    Heidenhain TNC 426 - Parameter / PLC
    Can anybody give how to view machine parameters and PLC programs in Heidenhain TNC 426 control used in Deckel Maho machines ?
    Jun 2006
    10
    426 Parameters
    [Prog Edit] Key
    [MOD] key
    Make sure you have a program called up in the [Prog Edit] screen
    General Use Parameters: 123
    Machine Parameters: 95148
    PLC: 807667
    May 2007
    49
    Thanks for your post.
    Sep 2011
    Dear all
    Please advice how to adjust the backlash in heidenhain TNC 426 controller.
    also give the parameter for adjusting the backlash.
    Thanks and regards,
    A.radhakrishnan
    Mar 2011
    DMU 80 Heidenhain 426 controller
    how do i re-load the software to a heidenhain 426 controller? i am having problems with the controller ereasing the program as it is running the program. i was told to re-load the soft ware for this controller. can anyone help with this. Thanks km8137
    Jul 2015
    20
    Re: Heidenhain TNC 426 - Parameter / PLC
    Can anybody help me with the files from the PLC directory from a milling machine DMC70V with TNC426 -SOFTWARE 280474 15. HDD is broken and the data from this folder I could not recover them.
    Aug 2006
    93
    dear All
    1- for seeing parameter on TNC 426 go to Edit mode ---select any program ---push MOD ---put 95148 then ENTER ---- for getting out just push END
    2-for adjust Back Lash try to correct value on MP710 as MP 710.0 X axis MP 710.1 Y axis MP 710.2 Z axis ....up to rest axis
    3-for HDD broken you need to have A- software 28047415 ( i can send you all soft you want ) ,..let me have your email , also you need same HDD as its easy to find in your local market this is easy procedure i send you step by step ,..just needs the machine parameter list or any back up you have ,[email protected] please send me any things you have ,..if you dont have i have same machine under my service i can prepare HDD to send you ,..its your Call
    thanks
    regards
    F.Sharifi
    Apr 2016
    Can you help me MP file not running Heidenhain TNC 426???
    https://www.youtube.com/watch?v=xgwH...ature=youtu.be
    Sep 2012
    6
    What happened now ?
    Please I also need the plc software
    [email protected]
    - - - Updated - - -
    [email protected]
    Aug 2023
    Hi i have a tnc 426 and the hdd is about to die. can someone help me how to replace it urgently.
    my email is [email protected]
    Mar 2021
    Hello,
    I need PLC software and MP for my deckel maho DMC70V milling maschine.
    Heidenhain TNC 426/430.
    NC Software 280476 18
    Please can you send me?
    Best regards
  1. heidenhain parameter export
    By ikennedy in forum Controller & Computer Solutions
    Last Post: 03-06-2013, 05:33 AM
  2. Parameter for: HEIDENHAIN TNC 407 B
    By elhosseiny in forum G-Code Programing
    Last Post: 08-22-2009, 08:49 AM
