586,060 active members*
4,521 visitors online*
    Jun 2017
    4
    AC sewing motor as spindle.....Any advice?
    Hi there,
    Just wanna ask has anybody tried using an ac industrial sewing motor as a milling motor spindle? I know using hybrid stepper motor as a spindle is a bad idea and I cannot afford to buy an AC servo. Getting treadmill motor is out of question for me as I am unable to find a controller that runs 220V ac of my country. Thank you.
    Sep 2005
    1740
    Re: AC sewing motor as spindle.....Any advice?
    Quote Originally Posted by tofurobotixs View Post
    Hi there,
    Treadmill motors are generally DC, so you would need to either purchase or build a AC to DC power supply rated at your motor amp draw. Used treadmills are on Craigslist here in US all the time and sometimes for cheap or free. You might be able to run using the Treadmill controller.
    My advice get a router motor with .250 (6mm) and .500 (12mm) collets that runs on 220 volts the power you have and has adjustable speed dial on the router.
    Dec 2005
    594
    He's asking for a motor for a milling machine, not a CNC router. The RPM's of a router would be too high for a typical milling machine, and lack much torque at the lower RPM's he'd need to be at for the harder metals.
    tofurobotix, check the Benchtop Machine forum. A number of folks in there have used the sewing machine motors. A lot will depend on the size of your machine as to whether the sewing machine motor will work for you.
    Mark
  1. Wiring setup for sewing machine motor?
    By jaru-eri in forum Taig Mills / Lathes
    Last Post: 05-22-2020, 02:35 PM
  2. Need advice on spindle motor
    By MarkedOne in forum Spindles / VFD
    Last Post: 01-25-2020, 10:45 PM
  3. G540 to Consew Type Servo Sewing Machine Motor
    By IdefixRC in forum Gecko Drives
    Last Post: 10-31-2019, 11:57 PM
  4. Replies: 0
    Last Post: 05-09-2019, 09:25 AM
  5. Which belt and pulley wheels for sewing machine motor?
    Last Post: 09-09-2018, 07:32 AM
