586,633 active members*
2,936 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Lead. Its heavy - has anyone CNC pocketed a mould for it?
Results 1 to 7 of 7
    Jun 2013
    443
    I have some double hung windows to make. Require 8 weights, and hows this, an 11kg sash weight here in NZ is around $120. Lead from the scrap dealer is $3kg......
    I reckon I am going to pocket out a mould and make my own weights. I was originally going to use alloy because I can machine that easily with my diy router. But, does anyone have a better idea for a medium to pocket out, easy enough to machine, easy enough to purchase for cheap, and would withstand moulten lead???
    You know what? I was even thinking about using Jarrah. The timber is so hard, I can tap a metric thread into it.
    Mar 2017
    411
    Re: Lead. Its heavy - has anyone CNC pocketed a mould for it?
    Why don't you try to use a cardboard tube for the mould. Cut the tube to the correct length, maybe use a wooden plug in the bottom and puor the led in. You can also use an eye bolt placed in the top of the tube instead of machining a hole.
    The melting temp of the led is low enough that I would bet that the cardboard will not combust.
    Mar 2017
    411
    Take a look at this.
    So, you can't put the lead directly in the cardboard, you should line it with aluminum foil or aluminum tape first.
    https://www.youtube.com/watch?v=fo7xxNplL9g
    Apr 2004
    5742
    Since lead melts at 612 degrees F and cardboard burns at about 450F, I'd be reluctant to trust a cardboard tube as a mold for lead, even if it was lined with foil. It would be safer to heat up some pieces of appropriate-sized steel pipe to drive off any residual water, plant them in a bucket of dry sand, and fill them with the lead. You can drill them for wire handles after it cools. Avoid touching the lead or breathing the fumes as it melts.
    Andrew Werby
    Website
    Feb 2015
    123
    I've seen videos on YouTube of guys using wooden molds to make fishing weights.
    Let know which way you go...and post up pictures.
    Rob
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Mar 2017
    411
    Quote Originally Posted by awerby View Post
    Not what I have found. Even the EXPERTS on the video said it would work. LOL. To each his own, but you make some good points.
    May 2015
    1422
    Lead's also really easy to mould up with plaster of paris - make a template out of whatever, a thin layer of plaster and then a couple of layers of plaster soaked newspaper strips. Do one half, vaseline coat the interface and do the other half. Leave it a few days to dry, then bury it in a bucket of sand and fill with lead. The sand supports it and acts as a safety catch-all in case of leaks.
  1. Replacing lead screws with 8mm lead in 2418 machine.
    By irvingma in forum Chinese Machines
    Last Post: 05-29-2019, 04:42 AM
  2. What happens to the air sat in the mould?
    By Scooby in forum Moldmaking
    Last Post: 01-13-2016, 09:11 AM
  3. Lead in Lead Out Corner Types Cut Order and More!
    By aldepoalo in forum BobCad-Cam
    Last Post: 03-09-2015, 11:07 PM
  4. Ramp toolpasth/Lead in-lead out (engage) question
    By MadPickinSkills in forum UG NX
    Last Post: 08-24-2013, 05:35 AM
  5. Replies: 3
    Last Post: 06-25-2013, 04:54 AM
