586,103 active members*
3,028 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Kitamura mycenter 0 axis over-travel
    Jul 2005
    207
    I managed to jog my Z too far (Towards the table) and now I am stuck with a E-stop alarm. Is there an easier way to jog it back off the limit other than removing the switch? The control is a yasnac i80m. I think its a 1996.
    Mar 2011
    Re: Kitamura mycenter 0 axis over-travel
    There should be an OT release switch or button that you hold on whilst moving the axis back into range via the MPG. It may be in a remote position that requires two people.
    Jul 2010
    7
    The second limit switch release toggle is located on the bottom row of switches on the control. Its the farthest left on the panel. If I remember correctly you need to press reset then hold the toggle switch up and manually jog off the switch. Once your off the limit switch you will probably need to home all axis'.
  1. Replies: 0
    Last Post: 03-14-2014, 03:15 PM
  2. Replies: 3
    Last Post: 08-08-2012, 11:05 AM
  3. Kitamura Mycenter 4th axis parameters
    By dmgood in forum Kitamura
    Last Post: 04-24-2012, 07:08 PM
