586,112 active members*
2,999 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Oil Matic MPSD what is it for and how to set it?
Results 1 to 10 of 10
    Feb 2016
    30
    Hello! I have Oil Matic MPSD-07-N-CE on my Okuma B200. I dont have any books or manuals for the oil matic and i cant find much on the internet. Found in PDF what MPSD stands for:
    M is for...model ?
    P is for High Precision
    S is for Cooling Main spindle
    D is for With tank
    Ok so in the morning the temperature shows around 23°C (outside temp is around 20°C) and later it shows around 28-29-30°C.
    I also found some settings in the PDF. By holding ENT and changing the next value to 10 (from 11) a new menu appeared before my eyes! It was "C" menu which was set to 45°C !? I set it to 25°C and it was holding that for about an hour (then my shift ended) +-0.1°C. I've never seen it holding one temperature before. Did i turned it ON ? Did i do something i wasn't supposed to do ? What did i do ? May someone explain me the benefits of holding constant 25°C and why am i cooling the main spindle for ?
    Jun 2015
    4154
    Re: Oil Matic MPSD what is it for and how to set it?
    hy, so far, everything seems fine ... please share that pdf if u wish, i will take a look about the settings
    it keeps the bearings chill
    Feb 2016
    30
    Its on the bottom of this page
    General Catalog (19MB)
    https://www.kantoseiki.co.jp/en/products/oilmatic.html
    Do i gain some precision by holding 25°C on the main spindle? What about my second spindle?
    I really hoped it is for the cutting fluid cause it gets like a bubble bath in there after 4 hours of constant work. The foam is rising for battle about 20cm and it gets rather warm...or its the fluid to blame ?
    Feb 2016
    30
    Ok so in the PDF they state that the ambient temp and oil temp should not have high difference...since the machine room temp is 15C in the morning and 30C after 5 hours...i'm gonna set it to Follow-up type (it was like that before i pushed buttons) rather than constant 25C.
    Aghh it's so hard with those machines....little to no info about this job....maaan it was so easy when i worked with computers, i could literally check everything and built my own damn operating system for nuclear power plant on mars...
    Feb 2016
    30
    This diagram shows that i'll be within range if i set it to 25C and room temp is +-10C. Any thoughts?
    Jun 2015
    4154
    ooh tarox ... i wish to congratulate you so you played with the device, and what happened ?!?! does this happens to you often ? i am pretty sure someone told you to push those buttons
    M is for...model ?
    aha, i feel you
    well, okuma's are made by people, people does mistakes ... make a complain to your okuma dealer ?
    i don't have a machine like yours, but i believe that the tank + mpsd unit, is serving both spindles; take a look behind the covers
    mpsd : cooling the agent for high precision spindles; tank included ...
    ... but let's get real : of course the unit is cooling the cutting fluid, because the spindle is much more expensive than a coolant pump + coolant pipes / i hope you get it
    however, you can buy another cooling unit for the cutting fluid ...
    my dear tarox, is normal for the cutting fluid to get higher temperature, especially after 4 hours of machining
    "follow up" requires less energy to operate
    no, is ok
    well, just ask for infos
    i don't know, good luck with whatever you are doing / kindly
    Apr 2009
    1262
    The more thermally stable your machine is, the more accurate it will be. The chiller unit is meant to keep your machine stable. That being said, it the ambient temperature varies by a large number from the chiller setting, condensation will occur and could cause moisture to get into your bearings. This could cause them to fail prematurely. For the best accuracy you will want a environment that remains at a consistent temperature and your chiller set to a fixed number. Since your temperature varies widely, you must set your unit to following so that the moisture does not occur by a large difference in chiller vs ambient temperature. Less accurate but still prevents overheating and gives longevity of the machine.
    The builder doesn’t know what environment the machine will go into so they set to following style to be safe.
    Best regards,
    Experience is what you get just after you needed it.
    Feb 2016
    30
    Quote Originally Posted by deadlykitten View Post
    Yeah my paycheck is very low so i push whatever i can to learn new stuff and go to the next level Of course i'm not like Diddy from Dexter's Laboratory pushing blindly. What happened? I learned what the unit does and how to set it up (i had no idea before). No one told me to push anything. You don't know how scared are the people in here to push a button...like literally scared...
    Thank you for the explanation!
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    Sounds logical. Any thoughts what could be the max difference between ambient temp and the cooled fluid ?
    I contacted Kanto Seiki (the manufacturer of the unit) and they sent me some more documents with settings and schemes but they didn't answer my question if its safe to operate the unit in constant mode 25C when room temp is 35C.
    Thanks for the replays!
    Jun 2015
    4154
    hi, i would leave the unit in follow-up mode, unless there would be some issues with part's dimensions ... however, okuma's are pretty rigid, tas-s & tas-c is default, and this should be enough for most parts
    did you experienced a deviation ? are parts dimensions within tolerances ? then is all ok
    machine can deliver a dimension with tolerance < 0.02..0.03 for a long time, like weeks so, i would worry, just a bit, only if tolerances should be < 0.01
    ... if machines is chilled, it will keep a narrow tolerance
    ... if tool is chilled, it will have a longer life
    the greater the temperature difference between ambient and mpsd-unit settings, the more stress on the mpsd unit ... also, like mr wizard said, moisture may appear
    you are very brave
    Feb 2016
    30
    I've never been in a fixed room temp so i'm constantly changing the tool offset correction but i can deliver parts with +-0.01 without a problem. 2 days since i'm in constant mode 25C....no difference at all. Switching to follow-up mode!
