586,551 active members*
3,441 visitors online*
IndustryArena Forum > CAM Software > EnRoute > Selecting one of multiple layered tool paths
    Does anyone know of a trick to select one of several tool paths stacked on top of each other for editing.
    My problem I sometimes have parts that need milled out, but may also have an edge treatment on one or more sides (just an open offset). These tool paths end up overlaping and look like one and if I need to edit one or the other sometimes I find that I can not get to one of them. Double clicking on the tool path to edit it always brings up the other tool path that I don't want to edit.
    So far the only way I've found to get to and edit the path I want is to start deleting stuff until I can get to the path I need to edit. That is very time consuming to go back and restore the parts I had to delete to edit the one tool path I couldn't get to.
    Jun 2018
    362
    Re: Selecting one of multiple layered tool paths
    No mention of what you are using. Use layers in the drawing software to generate specific tool paths.
    For example, an outline using an etching tool is on layer 1 (arbitrary layer number but a standard for drawing in your own environment would be recommended for best/common practices). The outline of a part may be etched to indicate overall dimensions, possibly engraving if used or other features.
    The same drawing object/entity would also be used to cut the outline on say the outer edge to free the part from the material. Copy the object to a different layer (with a different colour) for the actual cut (using a different tool). When you generate the tool paths, use the selected layers in the appropriate order, disabling those not needed for the operation/tool in your needed sequence.
    For example:
    Layer 1 (green) = etch/engrave
    Layer 2 (yellow) = pocket
    Layer 3 (blue) = drill
    Layer 4 (orange) = countersink
    Layer 5 (red) = cut part - outer-edge
    For operations using say "etch", enable multiple layers but for "cut" enable only layer 5.
    When you generate the g-code, it should be in sections (perhaps separated by tool change code) making it easier to identify the various operations. The completed file can be edited to add generous comments of what each section does. Alternately, use separate files for each operation/tool but this might be unsuitable for your needs.
    Others may have better ideas.
    I've found that having multiple pieces of the same part on different layers gets to be a big pain if you need to copy and paste it to different files or need to use the undo/redo at all.
    Jul 2014
    215
    Ya, I don't use that method as Enroute 5.1 is not reliable enough. It's best to keep toolpaths separated on different layers and just use one layer at a time. Even then sometimes Enroute gets mixed up on output. I have found it best to just keep the geometry on all the different layers and then only have one layer with toolpaths at a time.
    But if you click on some toolpath and select edit toolpath it gives you the option to choose which strategy you want if there are multiple different toolpaths. This is not a help if you have multiple stacked on the same geometry. Enroute is very weak for machining strategy organization compared to other modern software which will show the operations in a tree which you can reorder any way you want and see the order of operations visually. For Enroute you need to keep it simple to be successful. The geometry on the different layers can be as complex as you need. But for best results keep all of the toolpath strategies deleted except for the one layer you are working on.
  1. Selecting Multiple Parts As Stock
    By chronie in forum Mastercam
    Last Post: 03-10-2014, 02:15 AM
  2. Generate tool paths for multiple parts
    By vmehta211 in forum Mastercam
    Last Post: 11-23-2013, 07:28 PM
  3. Replies: 6
    Last Post: 11-23-2012, 03:29 AM
  4. Plasma- Multiple layered AL thin sheet cutting?
    By diyengineer in forum Waterjet General Topics
    Last Post: 08-22-2011, 12:06 AM
  5. SELECTING MULTIPLE LETTERS IN RHINOCAM
    By m.ryerson in forum Rhinocam
    Last Post: 05-30-2011, 08:45 AM
