Can the new Shop Sabres use R commands instead if IJ for radii?
Sent from my SM-G965U using Tapatalk
Scoob
I don't think it will, but you can ask the folks at wincnc that make the controller for them. Kelly or Mike over there are good people. It's not so much a shopsabre question but more of a wincnc question. Can I ask why you want to feed it different commands than what is normal?
I bought a used Shop Sabre and already had a post that used R for radii instead of I J K. After some tweaking I'll have a post that will kick out the right code for the machine. I was just thinking that if an update of the wincnc was capable of using R that I would go that route rather than spending the time on the post. So the short answer is I was lazy and hoping for an easy solution.
Scoob
Ken
Could you share what the wincnc code for a 1" pocketed circle is supposed to look like?
Scoob
Never mind Ken. I had to change the .ini file to non modal. Everything moves right now.
Scoob
