586,717 active members*
3,164 visitors online*
Results 1 to 7 of 7
    Jan 2011
    129
    My laser cutting Machine build---180Watt CO2 laser
    My laser cutting machine project started life as a Shizoka B3-V VMC (vertical machining center).
    Although the 180 W laser tube was added, it still can operate as a VMC mill. The final lens hardware is simply removed first.
    The original control system was replaced with a Warp9.com ESS motion control, a CNC4PC.com C62 Breakout board and CNCdrives servo drives.
    I retain the original FANUC servos and encoders.
    A fourth axis was configured using a stepper motor and drive from CNC4PC.com. This 4th axis can be used for regular milling or laser cutting.
    The control software is MACH3. It runs on a windows 10 “all-in-one” 21 inch touch screen computer.
    The laser is a 180 W RECI W8. The power supply is also RECI. The tube water supply is chilled via with a 1600W Water Chiller.
    The laser components were purchased through Lightobjects.com
    The laser tube is 73 inches long and is mounted vertically with no mirrors, Just a final lens.
    At full power it will cut 5 mm plywood nicely at 140 in./min.
    It will cut 1/2 inch cast acrylic at 15 in./min.
    I would like to thank the following people for their help on my project.
    Arturo with CNC4PC.COM
    Andy with
    WARP9.COM
    Tweakie with WARP9.COM
    Marco with
    Lightonjects.com
    Photos will follow.
    — need help adding photos —-
    Jan 2011
    129
    Quote Originally Posted by chuck767 View Post
    Andy with
    WARP9.COM
    Marco with
    Lightonjects.com
    Photos will follow.
    What’s the trick for adding photographs here?
    Jun 2015
    943
    Re: My laser cutting Machine build---180Watt CO2 laser
    There are some icons above the text box when typing a reply. Select the 3rd from the right which is the "insert image" and I think it is straight forward from there.
    Jan 2011
    129
    Quote Originally Posted by OlfCNC View Post
    thanks,
    looks simple enough.
    Jan 2011
    129
    Here are a few pics
    Attachment 425546
    Jan 2011
    129
ID:	425550Click image for larger version.
ID:	425552Click image for larger version.
    Jan 2011
    129
  1. metal sheet laser cutting machine fiber cutting or mix laser cutting
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2015, 09:03 AM
  2. Replies: 0
    Last Post: 05-17-2012, 02:29 AM
