I have a NM-200R2.
I purchased this machine for a design school for about $12000 and it just didn't fit into the curriculum so it wasn't used.
This machine has only about 20 hours of use in it's life and I have been trying to fix it off an on ever since it just stopped mid-cut one day.
I consulted with Novakon and they thought it was the BOB board so I replaced that as directed.
That didn't work so they suggested a new smooth stepper. That didn't work so I shipped the computer, BOB and smooth stepper to novakon and they tested it and said it was fine.
When I put it back together I accidentally crossed a wire and cooked the smooth stepper so I got a new one but that doesn't seem to be working either.
Now I need to move it out, fixed or not.
Make an offer. (I'm open to suggestions on a fix.)
You will have to pick up in Providence RI. We have a fork truck.
Here is what is included.
NM-200R2. Pro Series Bed Mill including 6K Spindle & REX
Motors with Attached Electrical Cabinet
Integrated Controller System
Full Computer Upgrade: Motherboard, CPU, 2GB RAM
Hard Drive & Windows 7 O/S
CNC Controller Software
NM-200 Coolant System with Pumps and necessary
cables
NM-200 R2 Stand
8" Rotary Table with Tailstock and Stepper Motor/Cable
4th Axis Gecko Driver Upgrade
(6") Vise, 160mm x 140mm Jaw Opening
5/8", 58 pc Clamp Set (for NM-200)
Collet Set, R8 Arbor with ER25 Collet Set (1mm -
16mm) and Wrench
Novakon Quick Change Tool
Collet Holder 3/4"-ER 20
ER20 Collets 1/8"
ER20 Collets 1/4"
ER Collets 3/8"
Keyless Drill Chuck, 5/8" x JT6
Hole boring cutting cutter adaptor
hole boring cutter set (9 PCS)
Hole Boring Tool Holder
