586,630 active members*
2,272 visitors online*
    Looking for a 3 axis for plywood
    I'm new here, (forgive my ignorance and stumbling around) and I'm considering a new or used CNC for cutting plywood parts to build small boats for children.
    Actual boats, using trolling motors.
    I'd like something idiot proof, easy to use, and preferably able to cut full 4 x 8 sheets of plywood.
    Any recommendations?
    Thanks!
    Re: Looking for a 3 axis for plywood
    4*8 feet ,1300*2500*200mm
    cutting plywood ,choose a bigger power spindle ,such as 4.5kw or 6kw
    New cnc user , choose easy control system ,such as DSPA11
    Software , what software you use ? just cutting work, Ucancam,Aspire etc
    Voltage ,220v1 220v3 380v3
    Table, aluminum T slot table ,hold wood with clamp +T slot
    bakelite vacuum T slot table , you can choose vacuum pump +seal line to hold plywood , or you choose clamp , a bigger power vacuum pump is necessary for bigger ,thicker plywood.
    Jun 2018
    362
    Welcome!
    No mention of where you are, plywood details (type, thickness etc) or budget but a full size machine for whole sheets is more expensive especially with rigidity for that size.
    Software to draw/generate G-code:
    1. Fusion360 is popular
    2. vCarve Pro is also popular but will cost $
    3. SimplyCam MR-Soft Nc Software Tools is very good at about $50.00
    4. Freeware (open-source) based on Linux is also popular
    Hardware:
    1. Build one - can be an arduous and time consuming process
    2. Kits - quite a few around - have a look through this forum, some are better than others
    3. Second hand machines can be a bargain or a lemon - try to see it in action before buying. A worn machine can be expensive to fix up.
    4. Made to order - Chinese typically
    There are some different opinions about a lot of the Chinese machines. They all "seem" to have common specifications as if they are all manufactured at a base level in the big "Chinese router frame plant" and then customised by the multitude of different "vendors".
    The Blue Elephant machines look interesting. There are many "vendors", some seem better than others. Many Chinese machines seem to be "assembled kits" and it is often necessary to "clean them up" and align them before any serious use. YMMV.
    Also, have a look at Remax ???? - Jinan Remax Machinery Technology Co.,Ltd
    I bought a machine from Remax about a year ago and after a few quirks and issues am very happy with it. They'll also build custom machines but be very careful about describing what you want. Use diagrams, pictures and be sure they get what you want right before starting the build.
    Jul 2018
    6420
    Hi Tom - Where are you on the planet? This matters for freight and companies etc. and your budget? Peter
    China air cooling spindle cut 15mm plywood
    https://youtu.be/MPkhhyDuYow
  1. First MDF/plywood CNC
    By Kazik_Wichura in forum DIY CNC Router Table Machines
    Last Post: 06-11-2012, 10:29 AM
  2. MDF vs Plywood
    By RockBoy in forum DIY CNC Router Table Machines
    Last Post: 01-17-2011, 05:24 PM
  3. MDF vs Plywood
    By Lurkepus in forum Commercial CNC Wood Routers
    Last Post: 10-08-2008, 12:19 PM
  4. best plywood
    By beamer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-06-2007, 11:27 PM
