586,096 active members*
2,962 visitors online*
Results 1 to 18 of 18
    Mar 2006
    427
    patio door rollers: Maybe?
    I was at the Home Depot today and I came across patio door rollers. I always keep and eye out for things that could be used or things that I could try, but I figured I would get your guys opinions first. What I was thinking was to take the rollers and using them on some 3/8 L beam steel. The L beam was the only steel there that was rounded over close to the patio bearings.
    Things that are coming off the top of my head are they can handle a lot of weight, Hell when I removed patio doors here at the house I need help to carry the glass to the truck.
    I see them sorta like v bearings just a u instead of a v. So what do you guys think just a waste of time or might be onto something. Any other ideals on what to use for the track?
    Here is a picture with a few close measurements.
    Dec 2006
    532
    I think they would work, but good improvement for it would be to put ball bearing in it. I think those rivet type shafts are not so precise to begin with.
    But how much are they? Will they compare to $12/ea. for v-groove bearings if you also compare precision?
    i had the same idea a while back but those bearings are too sloppy to work
    Jul 2005
    668
    Those bearings won't work, but there are some on the same rack that get closer. They are the lower bearings for the heavy glass patio doors. Look a lot like the real v-bearings. They have ball bearings, but are a little too sloppy as is.
    Steve
    DO SOMETHING, EVEN IF IT'S WRONG!
    May 2007
    12
    These the ones?
    I've been thinking the same thing about these little suckers. They're about $5 for 2. I've got two pix, showing the bearing and the side profile.
    there's about 1/32" of play in both the left/right, and the axial direction
    hmmmm... is it too much to ask to wonder if these will work with the v-aluminum some people are using?
    Dec 2006
    532
    hmm, what if you press that bearing out and put skate bearing in there... Whats diameter of that bearing?
    May 2007
    12
    hmmmmm
    i'm no bearing-ologist but they're about 17mm across, and 9mm thick. they appear to be made of two pieces, and they are pressed together, but I have no idea how to press them out.
    Dec 2006
    532
    Quote Originally Posted by olskool View Post
    posibly the same way you would press new bearings in, with press, either arbor or hydraulic?
    5/16 rod and a hammer breaks them apart , you can (carefully) grind back the one part about .01" to close up the gap ,they are very cheaply built and assembled ,the material is softer than what you would need for a proper bearing ,
    i came to the conclusion that i had wasted a few more bucks on research and developement
    Jul 2005
    668
    Quote Originally Posted by dertsap View Post
    Yea, I don't think they would be any good for a router.......I think I'll use them for a foam cutter. They ride very nice on 1/4" HR flat bar. Constructed from unistrut......hmmmm.....4 independent axes.....I can see the light!
    Steve
    Dec 2006
    532
    Quote Originally Posted by Madclicker View Post
    i agree, they might not like alot of load, but might be useful alternative to some other projects that require linear movement..
    Jul 2005
    668
    Quote Originally Posted by rustamd View Post
    Try them. Let us know how they work out. I wasn't happy with them and stopped at the $5 level.
    Steve
    Nov 2003
    244
    this guy believes it is possible.
    http://accurate-inspections.com/pr%20cnc%20upgrade/
    The MechMate site has a person whom used this type of bearing on his router
    MechMate is a open source router that is similar to the old shopbot.
    http://www.mechmate.com/forums/showt...t=sliding+door
    the problem a guy faces is :
    if you can get those bearings so they only have .002 slop at the bearing ,that .002 gets exaggerated the further your assembly extends past the bearings ,greatly exaggerated, in order to get them tight enough to take up the slack the bearings smoothness is lost ,the parts simply do not match up 100% ,if you go any tighter those bearings won t turn ,or bind
    another thing to concider is the out of roundness of the bearing , they are mass producted non precision parts
    if they are out of round ,then you would need to add that to the slop already there
    i have a dozen of them , one came out with somewhat smooth action , out of a few that ive modified ,
    ive done many abortions in my life and this one isn t worth it if a guy wants a 100% solid machine
    Dec 2006
    532
    I think you are looking at this from different side. This is just another alternative to homemade DIY linear movement.
    If guy wants 100% solid machine he better be using THK style rails and ball screws. I think that guy would have no room in DIY forum, just my ¢.02
    Remember this was just discussion:wave:
    i have my system in the diy forum , ive used v-groove bearings and it is very solid
    i had looked at it from the side your talking about , i tryed it and was not satisfied with the results ,i'm not telling anyone not to do it but concidering the fact i work with high precision machining i do have a fair bit of knowledge of the difficulties a few thousands of an inch can cause
    concidering ive tryed it , i thought i would share my 2 cent in this discussion
    good luck
    Jun 2006
    24
    Thumbs up
    I tried those for a non-cnc linear motion project about 5 years ago. ran them on some 1/4" or 3/16" (don't remember) rod tacked to the center of two sides of some 1/2" square tube. It didn't work they were just to sloppy. most of us have probably looked them over at some point and said hmmm.
    May 2005
    100
    These threads on this MechMate forum may be more applicable:
    Handmade V-Rollers
    Alternative ideas on V-roller shapes & materials
    Gerald
  1. How much do you preload these taper rollers?
    By phantomcow2 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-27-2006, 04:06 PM
  2. feeding rollers
    By DrStein99 in forum Linear and Rotary Motion
    Last Post: 07-26-2006, 03:44 AM
  3. Drive Rollers on Long Part
    By musicmkr in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2006, 11:58 PM
  4. Gear rollers
    By Bassbuilder in forum Mechanical Calculations/Engineering Design
    Last Post: 01-27-2005, 12:15 PM
  5. Sliding door tracks and rollers
    By Apples in forum Waterjet General Topics
    Last Post: 06-11-2004, 01:34 AM
