Does anyone have the procedure to turn on additional memory on the Mazak T Plus control
A tech who went out on his own did all 4 of my machines for me, for $0.00 too. I think Mazak charges a lot to do this too. Just something simple in the parameters but I don't know what it was.
Do you know the nameof the tech and how to reach him?
I'd like to do this also. Let us know if you find out.
I am trying to help a friend get a qt20 with tplus control up and running. Machine has set for 2 years and lost all parameters, have that taken care of now. machine had bar feeder removed and having to work around that. Looks like we may need to call in a tech. Hope someone can supply name and #
Still hopeing someone knows h0w to do a memory upgrade on a Mazatrol T Plus
I sure would like to know how to do this.....
If you have additional SRAM hardware, just change system parameter O42 as below:
O42(Max)
QX423(512K) 16
QX424(1M) 32
QX429(1.5M) 60
Hardware is mounted on upper mounting of IOC card QX524/QX521, make sure link pin is ON for backing up by super capacitor.
May not be so simple but give it a try, though I recommend backing up para/prog first.
Good luck.
